Results 1 to 4 of 4
Thread: What is more likely to get plugged? a Cat or a muffler?
    (2) 1989 2WD LE VAN Wagons
    Jan 2011
    Los Angeles
    I created an exhaust leak by removing my 02 sensors and my engine can now breath . If I mash the throttle to the floor the engine hesitates and backfires through the intake. When I removed the 02 sensors to effectively create an exhaust leak the engine was happy again with vastly improved throttle response. So what is likely causing the restriction? The Cat or the muffler.
    Apr 2015
    wherethevanisrare. FL
    Re: What is more likely to get plugged? a Cat or a muffler?
    The cat!
    I had this experience on my Mini. I was tracking the car, so the cat was getting hyper-heated every week-end, the core finally got loose and turned sideways in the can. The Mini chocked and went on limp mode!
    LG.
    1987 Toyota 4wd Cargo Van
    Aug 2016
    Lakeside, Az.
    Quote Originally Posted by JPERL View Post
    Typically it's the mesh/ honeycomb in the cat that gets plugged... the mufflr is just a series of baffles that has pretty big openings. I replaced my cat with a weld in for like 50 bucks, but it isn't .ca compliant...
    Doh! Carbonized beat me to it.
    Van Fan Cali Cruiser's Avatar
    1987 Toyota Van DX 2wd
    Mar 2017
    California
    My buddy owns a muffler shop. When I suspected a clogged cat, he drilled a hole with a step-drillbit on the angled portion of the cat near the inlet, so we could take a peek. My cat was still good, so he just welded up the "inspection hole".
    You could do this yourself. If you don't have a welder, you could use a tap to thread the hole and then put a bolt in the hole to seal it up. Otherwise, if the cat is bad, you will be replacing it anyway.
