- 0
2CT - Clutch Replacement
Hello all
I am in need of help! I cannot find a 2CT Clutch replacement for my 1989 Toyota Van: Master Ace Surf. 2CT engine - manual transmission. I am located in the Bay Area. I found a shop that will do the work and has done work on these old Toyota's before but they cannot help me source the part.
Please if you know where to find one - please let me know - or know where I should start looking!
My best,
Riley
Administrator
- 10
Re: 2CT - Clutch Replacement
I've ordered ADT rear brake shoes and master cylinder but I did email them with my chassis number before ordering to get the correct part for my 2WD TownAce. I'm not sure who would have this part locally or the cross reference part number without your chassis code. this is just an example based on limited info.
https://www.ebay.co.uk/itm/Clutch-Ki...0AAOSwNopdswm7
If you find the correct part please be sure to post the part number and brand in the Diesel section of the forum for future reference
Good luck
- 0
Hey Riley,
Were you able to get the part?
Was wondering--which shop did you end up using in the Bay Area?
- 0
I replaced the clutch on my 2WD 1991 Townace 2C-T last year. I bought an ADT clutch kit with the part no. ADT330178.
Fitted fine and is still working over a year later.
- 0
