Results 1 to 6 of 6
Thread: Suspension woes ..
    86 2wd auto LE 87 4wd 5spd
    Sep 2017
    East Tennesee
    Suspension woes ..
    I lost the upper ball joint drivers side , so I decided it was time to tear into it all . Finally found and purchased upper controll arm and lower ball joints and started on tearing it down . Now I am seeing I need the dustplates and might as well replace the lower controll arms as well as tie rods . I just need a little help finding all the RIGHT part numbers for the following :
    Lower control arm ass. with all the alighnment bushings , I show
    48068-28030 Lower Control Arm VAN; RIGHT
    48069-28030 Lower Control Arm VAN; LEFT
    and the steering knuckle (broke bolts off in it ....)
    43201-28010 Steering Knuckle Knuckle
    VAN; RIGHT
    43202-28010 Steering Knuckle Knuckle
    VAN; LEFT
    ANY help is truly appreciated , if anyone already knows a source ?
    Sep 2017
    East Tennesee
    Re: Suspension woes ..
    aaannnd I guess I really should do the CV axles ...can't seam to find them either ...
    1988 Master Ace Surf 4wd
    Jan 2018
    Northern California
    I recently had to replace the lower control arms on my van due to an accident. Everything I read on here stated that they were NLA. I was able to get a pair of NOS ones from Japan through the web sight jp-carparts.com. They weren't cheap (~$500 for the pair) but insurance payed for them in my case so I didn't really care. Came in about a week. I was pretty amazed as most people made them sound like pure unobtanium!
    Hope that helps!
    Sep 2017
    East Tennesee
    Ok it seams the lowers are NLA , I can only find 3 of the four bushings needed to rehab the old ones ...does anybody know of or have one or more ?
    Sep 2017
    East Tennesee
    So far I have found everything except ONE bushing for lower control arm AC Delco #45G9344 , andOil seal for steering knuckle Toyota part # 90316-6001 , 90316-6002 , and I need 2 of each? , it looks like febast might have that one , and I need both dustcovers Toyota part # 47781-28080 47782-28080 ....ANY help would be apreciated!!!!
    1987 Toyota Van 4x4
    Aug 2020
    Berkeley CA
    do you have the part numbers for the Tie Rods? tried using the search function but nothing is coming up when I search Tie Rods...seems strange....
