Results 1 to 9 of 9
Thread: Van ran fine, parked in garage and will no longer start
    1987 Cargo Van
    Apr 2020
    Canada
    Hello! A few days ago my van showed up from its 12 hour trailer ride and is finally home. I drove it off the trailer and did a quick loop around the block, seemed good to me. Parked it in the garage, and now when I go to start it, it cranks but doesnt start. From what I can hear, when I key on, I dont hear the fuel pump, but I'm not sure if it's just quiet in these. Didnt seem to be getting spark either, kind of lost now, as I don't know why I'd run into both those issues at the same time. Any help is appreciated, thanks
    !Name:  20200417_213824.jpg
    Jan 2017
    Tulsa
    Re: Van ran fine, parked in garage and will no longer start
    Pull a plug, especially since the motor in in the front seat and turn the motor over and look for spark.
    about getting fuel, ... these gauges stink, you could be out of gas...
    Vandi-
    '86 2wdAuto made it to 490k,now in van 'heaven' '88 panel 4x4 standard,,stolen in Tijuana jan 2012 '87 4x4 auto...new paint, now on th'road! '86 2wd auto 360k,,mint condition,had some fun, needs engi
    Jan 2012
    vancouver canada
    Sufficient voltage to starter?
    I remember once having a problem similar to what you're describing.,
    ...went to the starter shop,, but instead of selling me a fresh starter, they installed a capacitor just before the starter, to boost the voltage.
    It must be a common fix. I found one already installed in a subsequent van.
    1987 Cargo Van
    Apr 2020
    Canada
    Quote Originally Posted by Andywear View Post
    Made sure i added some fuel, that still didn't solve my issue. Found the 30a fuseable link for the ignition (the one behind the passenger seat under the floor) to be popped. Replaced that, started up!
    1987 Cargo Van
    Apr 2020
    Canada
    Quote Originally Posted by micah202 View Post
    It's funny, got it running yesterday, worked well for me for a while. Now it wont even crank, i just get a sort of clunk sound from the starter whenever I try to crank it. Possibly not enough voltage? Maybe a bad starter? Will certainly have to go get some voltage measurements though.
    1987 4WD Automatic
    Sep 2010
    On the outskirts of Mordor
    Have you perused this thread?
    https://www.toyotavantech.com/forum/...ther-Culprits)
    In Post #45 TimsRV talks about adding a booster relay to address low voltage/voltage loss from ignition to starter.
    Also look here post #4:
    https://www.toyotavantech.com/forum/...tions!&p=20678
    FYI, this was my situation after I bought my van:
    I had the starting problem for a year and a half before I finally had a bypass starter switch installed.
    2 new starters, new ignition switch, new neutral safety switch, several electrical trouble shooting campaigns, new battery cables, rebuilt starter with new copper contacts & new plunger, fusible link checked and tested ok, new big-ass battery, etc. But in the end the starter bypass switch was the only solution.
    Hope this helps, good luck!
    Jan 2012
    vancouver canada
    Quote Originally Posted by trestlehed View Post
    Hope this helps.
    Ahh yes,, that's what I was gettin at. <;~]
  8. 04-26-2020, 01:31 PM
  9. #8
    1987 Cargo Van
    Apr 2020
    Canada
    I read through this and it's entirely possible, but i ran a power probe from battery to the starter directly and still had the same issue
  10. #9
    (2) 1989 2WD LE VAN Wagons
    Jan 2011
    Los Angeles
    Quote Originally Posted by Galirom View Post
    There is no fuel pump prime by turning the ignition to on. The Fuel pump begins to run in the crank position as an rpm signal is needed and then air drawn into the AFM as the AFM has a fuel pump switch that is activated after the flap in the AFM begins to open.
