Results 1 to 14 of 14
Thread: MasterAce 2CT Turns over but won't start
    Toyota Masterace Sport Surf Grand Saloon
    Jun 2020
    UK
    Hi there,
    I've just got a Masterace Sport Surf Grand saloon with 2CT engine but it dosn't fire up...
    She turns over on the key fine, I've replaced the glow plugs and checked they're getting the correct voltage (all good there)
    Fresh Fuel, Also checked deisel is getting to the engine... might have turned her over with out the glowplugs in... a bit of spray then
    Anyways this is where I've got to and she still doesn't fire up.. Any advice on where to look/ tinker with next?
    I know before I got her she had been sat for a fair few years.
    Any thoughts thanks in advance,
    Jon
    Re: MasterAce 2CT Turns over but won't start
    Have you tried bleeding the injectors?
    Jun 2020
    UK
    Not yet I'll have a go and see how I get on.
    Is there anything specific on this engine to look out for (with regards to bleeding the injectors) or would following a standard injector bleeding guide be fine?
    Cheers,
    Jun 2020
    UK
    spotted this in the manual so will give it a shot and see how we get on
    Name:  2020-06-30 13_02_53-Window.jpg
    Cheers again,
    Jun 2020
    UK
    Still no luck, injectors bled, timing checked and correct. all vacuum hoses look fine..
    I guess next would be compression test. Unless anyone has any other ideas..
    Jan 2017
    Tulsa
    that's where my head went as well.
    Keep us posted
    Vandi-
    Jun 2020
    UK
    Thumbs up Re: MasterAce 2CT Turns over but won't start
    Just bought myself a Deisel compression tester so will wait for that to arrive, then let yous know how it goes
    Jun 2020
    UK
    So the test kit I bought doesn't seem to work as when cranking the needle bounces but doesnt hold a reading so thats getting returned and I'll have to wait again for another to arrive
    I'll let yous know when I get a chance to test it. in the mean-time is there anything I'd be able to check over whilst waiting for this kit to arrive?
    Cheers
    It's a diesel. Fuel and compression and it WILL start. You could unplug the glowplugs and give it a small shot of starting fluid(ether). If the glowplugs are not easy to disable you could let them cycle and then give them a couple minutes to cool down. You just don't want starting fluid going in there with the glowplugs hot. Check the oil too if you've been cranking it alot, it's possible to spray enough fuel in there to thin out the oil. If the oil seems excessively thin or smells heavily of diesel it can affect your ability to build enough compression and should be changed.
    Jun 2020
    UK
    Awesome thanks for that. Wouldn't be surprised if the oil is too thin after you've mentioned that.
    I will see what I can do with starting fluid also. Will update when I get a chance and also when the new comp tester arrives.
    Also I feel the seller told me at one point he tried putting start fluid down the air inlet and the engine "tried", could that have screwed the engine if he'd left the glow plugs in?
    Cheers
    Just to be clear, the glowplugs should physically be left in. You just don't want any electrical current going to them. Depending on the system, that could be simply pulling a fuse or unplugging the controller. If starting fluid is ignited by a hot glowplug when the engine has not completed the compression stroke it can kick back violently and potentially cause damage. This is also why I say to use a little. Too much will cause it to ignite before the compression stroke is complete. Start with a 1/2 second shot. You can always increase the amount if it doesn't fire and try again.
    Jun 2020
    UK
    Ah, that makes sense now.
    cheers originalkwyjibo, wish me luck
    Jon
    Jun 2020
    UK
    Okay so tried with some easy start and it definately fired breifly,
    guessing this means I have compression. at least in one cylinder
    it now turns quicker once the fuel is hooked up but still doest completely fire and run without the starter. I guess I should clean out the injectors next. Thats my next thought..
    I'll also be doing a proper compression test when the new tester arrives.
    Cheers,
    Jon
    Jun 2020
    UK
    Okay, new problem
    So new tester has arrived but my starter has decided to pack in. I took it out tested it an sure enough the solenoid is popping it out but the gear isnt spinning.
    so ordered new starter and just have to wait on that now. then will test compression and in the meantime - see if I can clean out the injectors.
