Results 21 to 25 of 25
Thread: MasterAce 2CT Turns over but won't start
    Re: MasterAce 2CT Turns over but won't start
    Hard to tell from the video but it sounds like injector nailing. This can be caused by the injectir popping too soon which affects the timing as well as allowing too large of fuel droplets. This may also account for what seems like excessive shaking in the video. Did you pop test the injectors after cleaning them? Does it mellow out after it's warmed up?
    Toyota Masterace Sport Surf Grand Saloon
    Jun 2020
    UK
    Cheers guys, I have some CT60 so might try running that through with a new fuel filter to clean out the "cobwebs".
    I didn't get to the point of running it warm as I was unsure of the sound I didn't want to risk damaging somthing but will give it a go and see how she sounds when warm.
    Also I don't have a pop tester so havn't had a chance to test the injectors since cleaning.
    I also remember adjusting the maximum fuel screw when trying to get it running, would this have an imact in the nailing at all?
    Thanks again for your replies,
    Jon
    1991 Toyota lite ace
    Dec 2018
    Nashville, TN
    Quote Originally Posted by Jon.Byles View Post
    spotted this in the manual so will give it a shot and see how we get on
    Name:  2020-06-30 13_02_53-Window.jpg
    Cheers again,
    hey way just wondering where you got this manual!?! Any help would
    be appreciated.
    Jun 2020
    UK
    There was a link to it on another thread but here it is also: https://drive.google.com/drive/folde...gu?usp=sharing
    It could do with being compiled into a single PDF but still works as is.
    Hope it helps,
    Jon
    Jun 2020
    UK
    Had a chance to run her warm this eve and I also replaced the fuel filter and put some deisel additive "ct60" in the filter & tank.
    She's running much better now no smoke, a little white to start with but now nothing.
    However still a knocking of some sort, though doesn't sound as bad:
    Any thoughts would be much appreciated.
