Need to install new door lock set
Hello! I need to install a new set of door locks, and the back hatch door of my van doesn't open at all. Ive already got a new ignition cylinder in there with matching key.
Most of the cheapo aftermarket door lock sets I'm seeing only come in pairs and I need the trunk too... Any advice on if they will work ok? The full Toyota set seems pricy given that I dont need the ignition cyl, just door/trunk set.
https://www.toyotapartsdeal.com/oem-..._cylinder.html
Re: Need to install new door lock set
If you get them at a local auto parts store just ask them to match the cylinders. These cylinders usually come with a generic factory number that can be matched to other cylinders.
