Results 1 to 4 of 4
Thread: 2C Timing Belt replacement
    LiteAce '94
    Jun 2020
    NJ
    Hi, I'm new to this forum. I found this site is full of information on Toyota vans.
    I recently bought '94 Liteace JDM camper van with 30k miles on the clock. I am replacing all possible maintenance parts (i.e. belts, fluids, etc) as much as possible since it's from Japan and has no service history.
    When it comes to timing belt, my mechanic asked me to get 'belt tensioner'. Catalog says the belt is #13568-69066 but no mention of tensioner. He is not familiar with JDM cars so he may be referring to general parts needed for replacing timing belts. I am mechanically challenged so I have no clue either.
    Could anyone point me to any threads discussing timing belt replacement for 2C engine and tell me what other parts do I need to replace while working on the timing belt?
    Many thanks in advance.
    1991 Toyota LiteAce 4x4 diesel JDM
    Nov 2019
    Austin
    Re: 2C Timing Belt replacement
    Get yourself intimately familiar with the parts diagrams that you can find at Megazip.net. It will give you the exploded parts diagram and the appropriate Toyota parts number.
    Jan 2017
    Tulsa
    welcome to the group.
    the manual is somewhere on this site I downloaded and used it greatly when doing my TB.
    thread is here
    https://www.toyotavantech.com/forum/...ng-belt-change
    I only did the belt not the tensioner. the tensioner is just a spring to keep pressure on the belt.
    the diesel forum only has 6 pages of threads. thumb through all of them and get familiar with the van. Your mechanic will not unless you got deep pockets.
    Vandi-
    SEATTLE, WA
    Check out this link-
    https://www.ebay.co.uk/itm/Tensioner...EAAOSwaQtctGOU
    Call or email you chassis code to make sure it’s the correct part and maybe they’ll also have a few other parts your looking for... make a list and check it twice and make a inquiry.
    Good luck
