Results 1 to 11 of 11
Thread: 1987 4wd automatic does not want to shift easily
    1987 4wd
    Aug 2020
    Portland
    I have a 1987 4WD automatic. Recently had work performed on the van in which it was taken to a transmission shop to look it over(previous owner had records of the transmission being rebuilt within a couple thousand miles of me purchasing it from him). The van seems to not want to shift unless I let off the gas for a second, then get back on the gas and then it shifts. I’ll be at 3000-5000 rpm and it’s not shifting into the next gear. Since getting it back from the transmission shop, the issue seems to be worse, especially for 3rd and 4th gear. The van has 260,000+ miles on it. Is this par for the course or fixable? While this is a 4WD van, I haven’t even tried the 4wd, these issues are all for when it’s not in 4wd. Thanks for helping out a newbie who isn’t super mechanically inclined.
    1987 4WD Automatic
    Sep 2010
    On the outskirts of Mordor
    Re: 1987 4wd automatic does not want to shift easily
    Use the search function and enter: "transmission kick-down cable".
    (2) 1989 2WD LE VAN Wagons
    Jan 2011
    Los Angeles
    These cables stretch over time and need to be replaced but there are no replacement Throttle cables unfortunately. You may need to get a cable custom made
    1987 Toyota Van 4x4
    Aug 2020
    Berkeley CA
    I have the exact same issue on the exact same van...so is it a transmission kick-down cable or a throttle cable that would be causing this, and which one would need to be custom made?
    Thanks for the help ya'll !
    1987 Toyota Van 4x4
    Aug 2020
    Berkeley CA
    ah, I see from another thread they are the same thing.
    1987 Toyota Van 4x4
    Aug 2020
    Berkeley CA
    Jan 2011
    Los Angeles
    That pioneer one is way to short been there bought that and returned
    1987 Toyota Van 4x4
    Aug 2020
    Berkeley CA
    Good to know thanks. That's super annoying.
    1987 Toyota Van 4x4
    Aug 2020
    Berkeley CA
    Check out this thread, lots of info. Im gonna try the lube trick with my mechanic at some point and see if that helps. I wish I'd seen this thread earlier because I just had the TPS sensor and throttle body cleaning done.
    http://www.toyotavantech.com/forum/s...months-sitting
    1987 Toyota Van 4x4
    Aug 2020
    Berkeley CA
    Jan 2011
    Los Angeles
    nope not even close. The cables for the van enter the transmission case and connect internally to the valve body. The cables are only a few mm thick and don't allow for barely any clearances
