I'm new to the site and I'm looking for some advice. I have a 1986 RWD with a 4YE that i cannot keep running, I installed an external fuel pump. Fuel is getting to the filter and fuel rail. The van will start with the help of ether sprayed into the engine, but the van will not continue to run. It has compression, it has fuel, it has air. I'm left clueless, i've checked my fuses they are all good. I'm not sure if maybe theres a sensor? or loose wire? is there a special trick to get it to run? any help would be greatly appreciated!
