1995 Previa has fuel & Spark but won't stay running
Hi,
my Previa died today while traellingv. I checked for Spark & Fuel getting positive results. It will try to start & run for 1 sec. then dies. I replaced the Fuel Filter, but no improvement. All Fuses are good. I tried a 2nd Fuel Pump Relay with no change. Not to say both aren't bad.
Can anyone be of further help?
Re: 1995 Previa has fuel & Spark but won't stay running
Have you checked for codes?
I haven't found a way to get my code reader to give codes unless car is running
Mine is ODB2. My best guess was the Fuel Pump, so am replacing now.
Just finished installing new Fuel Pump & Strainer. Unfortunately no change
Turns out I was way off on the cause. The Pipe splice from the Supercharger to Intercooler had separated. It is secured with a double layer Seal.. I'm not sure if the one layer was supposed to be inside the tube from the SC. I believe the SC Tube is sized to slip over the Intercooler outlet. There was only one Hose Clamp installed
