Rear springs for 88 4wd TV
Hi everyone, I am looking to lower my lift to a more stock height. Does anyone have any ideas on if you can still get oem rear springs? Or any advice on the job at hand?
Administrator
- 10
Re: Rear springs for 88 4wd TV
Have you looked to see if maybe the stock springs are still in there and maybe some spacers were installed to give it a lift, that would be ideal!!
Have a look at these threads maybe the answer is in one of them-
https://www.toyotavantech.com/forum/...lifted+spacers
There maybe some more threads on lifting the van, go to the search feature and type in some key words and see what comes up ie "lifted coil springs" something like that. When you find the thread that is close to what your looking for then post in that thread to notify members that have posted and to continue building that thread. Good Luck
Thanks, I did look at the rear springs closely and no spacers were put in. I will check out the threads you suggested.
