Results 1 to 7 of 7
Thread: EGR Delete/Blocking Plate for 3C-T
    1994 Townace Royal Lounge 3C-T 4WD
    Nov 2020
    Ojai, CA
    Anyone got rid of their egr? Any kits available or will i need to fabricate a plate myself?
    1993 Toyota Town Ace 2.2D 4x4
    Aug 2019
    Fort Worth
    Re: EGR Delete/Blocking Plate for 3C-T
    There's pretty much nothing aftermarket for these vans. However I'm hoping that more and more folks on this forum will start offering up their mod instructions and designs for upgrades!
    Best of luck!
    1996 Toyota HiAce 3.0TD 4WD Super Custom E-Spirit
    May 2022
    Portland, OR
    Quote Originally Posted by wynnieblues View Post
    www.VanLifeNorthwest.com sells a kit.
    Here's the link.
    https://www.vanlifenorthwest.com/pro...-1kz-te-engine
    1996 Townace
    Mar 2022
    Portland
    Did you ever go about finding or making one?
    1990 Masterace Surf, 2ct, 4wd
    Apr 2022
    very easy to make one or have one made. Making one for my 2ct engine cost about $2 in steel and another $3 in bolts/washers/spacer. Just have to use a spacer as the studs are a bit too long for the new blocking plate on my engine. $69 is a lot of money for a plate. I would guess any metal fab person could cut you out one of those for less.
    You may need a new gasket(s). I used ultra red hi temp RTV and waiting to see if it springs a leak. Couple hundred miles in and no issue yet.
    Toyota townace 4wd 1992 2ct
    Oct 2022
    Queenstown Nz
    Any help finding the Egr valve? I'd like to try to this myself but not familiar with the egr systems
    1996 Townace
    Mar 2022
    Portland
    does the 1kz EGR delete work on the 3C-T?
