pm sent
pm sent
I hope that I am not too late. I bought an 87 4wd. I was out driving it last night when a little fire started under the passenger seat. It was fairly contained but the heater box and associated wiring are toast. I would love all of the heater parts and the access covers. Thanks in advance, Tristan.
Tristan,
I'll send you a PM later but I unloaded the van a couple of weeks ago so I'm limited in the parts that I have right now. If you're able to post pictures I may have more parts you need but I don't have the rear a/c stuff; it's a bummer too since those were in the van when it got crushed.
Hi there! Looking for the engine cover panel clip under the drivers seat. Is this available? I am in Tucson! Thanks!
I could use the right rear tail light. We poked a hole in the red part of ours so we only need that part, but I assume it comes with the whole tail light assembly - shipped to St. Louis, MO.
I know this is a long shot. I really need a radiator for an 86 2wd. Recoring isn't an option due to rust damage
Is the bellhousing available?
Hello AD2101, I’m looking for the drivers side rear quarter glass and gasket, center console for manual shifter, rear wiper blade arm, dome lights and such. If they are still available, could you please contact me, I am also in Arizona, and San Diego, so I’m close to Tucson. Thank you
Radiator??
Rear bench seat?
I need the charcoal canister please
This may also be a long shot, but do you have the fan shroud for the radiator? I also need the drivers side master switch for the windows (and door locks), and the plastic cover for the rear bench seat belt (it's small and mounts on the wall of our vans, and hides the bolt for the shoulder seat belt). I could also use the arm rest for the front seat passenger seat.
Any chance you have the dome light cover for the rear passenger compartment?
Hey Perry - I need the arm rest of the front passenger seat, and the seat bolt covers from the rear bench seat ( located on the rear wall of the van , right and left. I also need the radiator shroud
One other thing - the rear climate control panel with intact cables
I meant seat belt bolt covers (plastic covers)
