Results 1 to 7 of 7
Thread: van doesn't start, with turn of key there's no cranking, clicking it's silent
    87 toyota vanwagon
    Dec 2020
    LA
    Hi,
    hoping someone can help. Van doesn't start, with turn of key there's no cranking, no clicking..... it's silent.
    Prior to this it's been difficult to start, but would eventually catch and fire up. Drove to Long Beach and back today, 40 miles and now it wont start. It's locked in Park, won't shift into gear at all, so can't roll it. Could this be a solenoid issue ?
    Ive checked fusible links, they all seem fine. Battery measures 9.8 with multimeter.
    Name:  Screenshot 2021-03-23 at 4.52.26 PM.jpg
Size:  14.7 KBName:  Screenshot 2021-03-23 at 4.52.40 PM.jpg
    also, the nuts were loose on this component beside the battery, what is this component ? sorry, total newbie
    thanks in advance
    Re: van doesn't start, with turn of key there's no cranking, clicking it's silent
    12.2V would be considered fully discharged, so probably start with a new battery and go from there.
    Out of curiosity, how did you "check" the fusible links?
    (A visual is not sufficient.)
    No clue on thing beside battery
    IG:@dialupthevan 89 - 2WD - 201k 87 - 4WD - 188K
    Feb 2016
    Los Angeles, California
    Sounds like a dead battery and yes visual in not enough. Test for continuity in each fusible link
    That smells like regular! She needs premium DUDE! PREMIUM!
    87 toyota vanwagon
    Dec 2020
    LA
    battery held charge of 9.8
    jumped battery and it started.
    fusible links were fine when checked with multimeter
    checked battery today and it measures 12.6. climbs to 14 when van is running.
    87 toyota vanwagon
    Dec 2020
    LA
    ohmmeter
    87 toyota vanwagon
    Dec 2020
    LA
    pulled the wire from the battery whilst van was running with christmas tree dash ... and engine cut out. So, after reading this excellent thread: https://www.toyotavantech.com/forum/...tor-woes/page7
    i ordered a new alternator from here: https://www.toyotapartsdeal.com/oem/...del=&Filter=()
    This forum is a trove of information. Apologies for not trawling deeper, initially.
    Aug 2021
    Puerto rico
    Quote Originally Posted by pigneguy View Post
    Hi,
    thanks in advance
    that is the starter relay that is located in the passenger seat behind the power sterring liquid pump there is a box with 4 fuses under that box is the relay that I discovered today since mine stopped turning on by the key I changed it and it turned on
