Results 1 to 2 of 2
Thread: Replaced cig lighter with 12V USB voltmeter and charger
    1987 4WD LE
    Jan 2021
    CA
    Thought I'd share a small project that was fairly easy to do below and looks factory.
    • Purchased a $15.00 YONHAN brand Quick Charge 3.0 Dual USB Car Charger with Voltmeter: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1. The charger seems well made, with a metal housing and on/off switch.
    • Removed the radio trim panel (with the help of posts here)
    • Removed the cigarette lighter and wire clip to the wire harness
    • Disconnected the green and red wires to the small bulb that lights up the cigarette lighter- decided to "delete" this so I took the bulb out, taped the socket off, and totally remove it from the cig light housing
    • Connected the van wire harness red/black to the solid red of the 12V voltmeter/charger
    • Connected the van wire harness black/red to the solid black of the 12V voltmeter/charger
    • Drilled the cig lighter hole a bit larger and grinded off the two tabs behind the trim panel
    Sorry, the photos are a bit glary as the blue LED display is bright- in a dark garage. There are two USB 3.0 charger sockets with above and below the display. The USB 12V charger/voltmeter has a cap with a window- I ended up cutting it out, but using the the round back part as a washer between the mounting of the charger and into the hole so it grips better and less likely to loosen over time. There is a round threaded ring the secures it in place.
    I used solder and heat shrink to secure the connections ad pushed the wires behind the dash for a clean look, reusing the factory wire harness. The wires that come with the USB charger/voltmeter are long, so I had to trim and strip them On the heat shrink, remember to insert the heatshrink tube on one end before you solder the connections (lesson learned!).
    Just my small contribution to this forum, you all have been helpful. Thank you.
    SEATTLE, WA
    Re: Replaced cig lighter with 12V USB voltmeter and charger
    NICE JOB, thank you creating this detailed post
