Differential seeping
TVT Friends,
On the 4WD, my differential looks like it seeping fluid from the front side, facing the back of the engine. I changed the diff oil and the level seemed fine prior to the change.
I can't seem to fine a thread on this, but wanted to know if there is a gasket or, simply, what's the work like in this area to make sure it's sealed.
Administrator
- 10
Re: Differential seeping
I typed in "differential seal" and 29 threads came up, give that a try and see which one is closest to the issue your experiencing and post in that thread this will notify other members and get a quicker reply.
Good luck
