A/C Suction, Discharge hoses and rear blower resistor
Friends, I need to change out the A/C Suction and Discharge hoses to the compressor on an 87 Auto 4WD LE. I also need to change out the rear blower resistor (only works on high). I reviewed the shop manual but it's quite general but doesn't show or provide too much detail.
Kindly, can anyone help in telling me where the rear blower resistor is and how/best to remove? I think I located it behind the front pass seat, in the plastic evap area assembly (is that right?). If so, how is this removed?
As for the hoses, I think I can reach that with removing the oil filter access panel and start there.
Thank you in advance for the help.
