Hey there,
I recently picked up a 97 Previa SC All-Trac with 240k miles. Loving the Previa so far! Overall the van is in good shape, and the previous owner had a decent amount of recent maintenance done at a shop, although not in a holistic manner. I've got the factory service manual, and have already dealt with the leaking valve cover and am working my way through the fluids.
While stopped in drive there's a good amount of engine vibration, while in neutral it is smooth. I'm thinking this would rule out a SADs issue? I'd like to replace the engine mount(s) as a first step, but can only find reference to the right side mount. Surely there's not just one? Also, for the transmission mounts, do you have to buy the inserts and press them in, or can you get the entire mounts somewhere?
I tried various searches, but couldn't find a thread specifically about mounts so apologies if this has been covered.
Cheers,
Matt
