Results 1 to 9 of 9
Thread: Rear wheel bearing
    1986 toyota van le
    Dec 2016
    kelowna, bc
    Rear wheel bearing
    Hello everybody...im getting ready to do the rear wheel bearing on my 1986 toyota van (standard, 2wd if that makes a difference) and im seeing a few different looking parts being sold as a "rear wheel bearing"....im leaning towards this one http://www.rockauto.com/en/moreinfo....279751&jsn=410
    Is this the right part? will i need anything else to do this other than possibly a slide hammer? Also, the method of heating the new bearing up in gear oil and pressing it in worries me...is it possible to just bring the axle shaft to a shop after it has been removed and have them do it or will they need the entire van in the shop?
    Thanks for any help in advance, sorry if i sound so clueless but ive never even done drum breaks, let alone take apart a rear axle so im a little worried about my abilities... :p
    1985 van wagon 1986 van cargo
    Oct 2011
    buffalo,ny
    Re: Rear wheel bearing
    A slide hammer is useful to remove the axles. I purchased the bearings from Rock Auto and had the local machine shop install them.
    1987 4wd 1986 LE
    Feb 2014
    NC
    Re: Rear wheel bearing and axle removal
    (Quoted from a Previa thread)
    Quote Originally Posted by Rufus View Post
    Be careful to install the retainer with the flanged end facing the correct direction.
    Does the flanged(rounded) end go toward the oil seal and the flat side against the bearing? I think that is how it was when I took it off but should have payed closer attention.
    Jan 2016
    Red Bluff, Ca
    Quote Originally Posted by lamont View Post
    Yes, you are correct!
    1987 4wd 1986 LE
    Feb 2014
    NC
    Got the retainer on tonight and was ready to put axle back in but.....the axle is flopping around! I think I may have the wrong bearing. The outside diameter of the bearing is appx. 2.820 inches which is much smaller than the opening it is supposed to fit into. Am I overlooking something? The van is a 1985 model and I ordered the bearings from rockauto. And I dont have the old bearing to compare the new one to...it has already been thrown away.
    1987 4wd 1986 LE
    Feb 2014
    NC
    After some further research and checking bearing specs, It seems that the rear bearing for 1984-85 vans was a smaller diameter bearing than the ones used from 1986-1989. So the bearing I ordered was the correct bearing for a 1985 van but it is the wrong size. WHAT????? Well it seems my 1985 van has a 1986 or above rear end! I do not know if a previous owner changed it or if maybe the factory put some 86 rear ends in 85 vans. Anyway, time to remove the new bearing I just put on and wait for my new LARGER bearing to arrive! So if you plan to do this job, be sure to measure the O.D. (outside diameter) of your old bearing before ordering your new bearings.
    1991 Toyota Previa 1985 Toyota Van
    Nov 2020
    Pennsylvania
    Sorry to hijack an old thread, but I was wondering, are these rear bearings packed with grease, or are they lubricated with the gear oil from the rear diff?
    Van Fan AnotherUser's Avatar
    1986, 2wd
    Pacific Northwest
    Can someone familiar with rear bearing replacement provide a quick overview of the process for replacing them on a '86 2WD?
    I've read that you might need to get them machine pressed in? Is rear bearing replacement considered a difficult job on these vans?
    1985 automatic
    Jan 2021
    Victoria, B.C. Canada
    You do need a hydraulic press to press in the new bearing and retainer. I also used one to press out the old bearing. The pdf attached shows the procedure according to the factory service manual:018_REARAXLEANDSUSPENSION.PDF
