offman-j
Ok so I got a 94 previa no s/c. Had some issues with the distributor so I replaced it and while replacing the starter went out. So trying to replace that too. Long story short of me trying to diagnose problems and making more I need to manually crank engine so that a.) the old starter can be removed because right now starter is lodged in with all bolts removed it’s not moving. And b.) I want to make sure that I have the distributor installed correctly and pointing at 1 spark plug. ...
