- 0
Speedometer and odometer both stoped working
1989 4x4 Vanwagon manual transmission.
The speedometer/odometer/miles counter all stopped working.
Any ideas?
could it be the speed sensor or a wiring issue?
Re: Speedometer and odometer both stoped working
Your speedometer is cable driven. Check the drive cable for damage particularly the 90 degree fitting at the transfer case.
- 0
I had the same issue and it turned out my speedometer cable was shot. If you are in PDX I highly recommend this place https://www.speedometerserviceportland.com/. Steve charged my $60 for a new cable and he made it in a day. Now my Speedo and odo both work!
