Results 1 to 2 of 2
Thread: Bad driveshaft vibration - May I?
    '95 Previa S/C Alltrac
    Jun 2021
    the Great Pacific NW
    My '95 Alltrac has a really bad driveshaft vibration when accelerating so I'm thinking it might be out-of-balance -
    Also thinking the U-joints are shot because there's a little *hesitation then catch* clunk half the time when accelerator pedal is depressed at speed.
    I recently replaced a *destroyed* carrier bearing hoping that would fix the problem, but no luck.
    For what it's worth, the 'SADS' couplers are also new.
    I've been sinking a lot of money into the van, and can't quite bring myself to spend the $1000+ to put into driveshaft replacements right now.
    I'm wondering:
    How to identify whether it's the FWD or RWD shaft that's causing the issue?
    Can I disconnect the problem shaft to possibly eliminate the vibration issue? (And just have a temporary 2WD Previa?)
    If I'm correct on diagnosis...that these are symptoms of viscous coupler problem?
    Help much appreciated!
    Nov 2014
    Midwest/Southwest/Northwest
    Re: Bad driveshaft vibration - May I?
    you should be able to grab the shaft near the joint and feel for play in it in order to determine which u-joint is at fault. You cant drive the 95 far without the rear shaft, the van will lose all drive power and you'll need a tow. Earlier ones (at least the 91) weren't as "smart", so you could drive without it but you absolutely needed the emergency brake when parked because "Park" wouldn't hold.
