Results 1 to 9 of 9
Thread: Heater flow issue
    YH51
    May 2018
    in the lounge
    Heater flow issue
    I have an issue with no heat in my van.
    - 1984 Hiace YH51
    - 3Y motor
    - Don't have any overheating issues and gauge sits where it always has for the past 20 plus years.
    - Have replaced the heater control tap and verified that it is open
    - Have replaced the thermostat and all hoses recently
    - New radiator 12 months ago as the last one sprung a leak.
    - System has been flushed a couple of times and is clean
    - Heater core has been flushed separately in both directions and seems to have good flow
    - Have removed the heater hoses from the core and started the engine but nothing pumps through the hoses.
    - If I connect a hose to the disconnected heater hoses I can push water through the system in both directions which suggests that it is not a blockage and that the thermostat is open
    - Have idled the motor at length to get it hot and increased revs without any obvious hose collapse
    My initial thoughts were that I had a blocked core and not wanting to pull half of the car apart to fix it I flushed it out but no cigar. I haven't had any overheating issues so assume that the water pump is working correctly, just don;t get any flow through the heater hoses.
    What circulates water through the heater hoses? Is it the general flow of water through the system? If so then why does water not flow when it flows freely with hoses disconnected and connected to a garden hose? Does the water pump perhaps have a separate function for circulating water through the heater and this part is defective even though the general circulation seems to be ok?
    Would appreciate any thoughts as it is a bit chilly driving to work in the morning and having to use cold air for demisting the windscreen.
    Tools
    Re: Heater flow issue
    You can find documentation on the heater hose routing for US Vans HERE.
    Water (and/or coolant) is circulated through the heater hoses entirely with the water pump, thus moving while the engine is actually running ... IF the valve in the heater hose is in the open position. For the symptoms you describe, I'd track down that valve first and investigate whether it's in the closed or open position. For a US Van, that shut-off valve is showing in the fourth photo in the linked article above. The valve itself could be the issue, but more often the control cables are the problem (stuck, broken, or detached), and you will need to manually change the position at the valve until the control cable issue is resolved.
    A thread about the heater valve is HERE.
    YH51
    May 2018
    in the lounge
    Thanks Gwen. I have already confirmed that the valve is open, so it is purely an issue of no water flow.
    Tools
    Theres also a couple of threads regarding bleeding the cooling system, it can be difficult to get all the air out of the core, due to its location/orientation.
    Van Fan Harbilly's Avatar
    gwen’s got it. The spider at the dash fails. We’ve been sliding under the nose to manually adjust the heater valve on our cargo van for 16 years. it used to be annoying but now we have children big enough to do it for us at $1 a pop. I realize your valve is open and this doesn’t help you but it’s the most common thing to know and useful advice in most situations.
    you might have an air lock. Water pump could be weak - that’s an easy enough swap out. How about a gunked up and blocked hose from rust and flushing? I read you pushed water through things but did you get all the way back to block? We leave the valves partially open on the heaters all the time just to keep things flowing and prevent jam ups.
    86 2wd cargo
    96 (3rd Gen) 4Runner Limited
    after doing anything to the cooling/heating system we start up in the am with the rad cap off and idle for a bit while bubbles find their way to the cap neck and go away. Heater valve wide open. Rear heater too. 2-6 weeks has always worked for us in terms of getting the air out. FWIW. Ymmv.
    86 2wd cargo
    YH51
    May 2018
    in the lounge
    I ended up pulling the core out and having it re-cored and now I have heat like I never had before. It must need pressure in the system for water to flow as it works beautifully now that it is all sealed up.
    I removed the core without removing the dash, but did cause some minor trauma to the pipes when doing so, but it meant I still had the van in one piece to drive while the core was being redone. I pulled the dash out to reinstall and I reckon it only took a bit over 2 hours and it was all back together so not as bad as I was expecting.
    Tools
    Do you mind if I ask the cost and location of the recore?
    YH51
    May 2018
    in the lounge
    Unfortunately I am in Australia so my guy won't be able to help you! I paid about 220AUD (about 160USD) and he pulled it apart and welded in a similar sized generic core, and welded the pipes I damaged back on as well....If I had known it was going to be as simple as it was then I would have done it years ago.
