Results 1 to 4 of 4
Thread: Steering Wheel Replacement (Van Wagon)
    Van Fan alexpski's Avatar
    PAST: ‘89 Van and a ‘92 Previa. PRESENT: ‘85 Van
    Nov 2017
    Brockport NY
    I searched and could not locate on this forum anything about removing the steering wheel on a VanWagon.
    Nothing found in Google or Youtube specifically for this vehicle.
    Anyone done this and have any tutorials or guidance?
    Re: Steering Wheel Replacement (Van Wagon)
    The horn pad is held on with screws from the back side
    Mark the position of the wheel to the shaft
    Remove nut, install puller, pull wheel
    If you don't have a puller, put the nut back on a few turns and use the palm of your hand or a rubber mallet and hit the back side of the wheel, alternating blows, till it pops free.
    The reason for putting the nut back on a few turns is so you don't have to go to the hospital to get that broken nose fixed.
    Nov 2017
    Brockport NY
    Sounds easy enough! Thank you for the advice
    Van Enthusiast 89van's Avatar
    Jul 2021
    Phoenix, AZ
    Replying to what Burntboot meant, heres a proper thread for the steering wheel removal:
    https://www.toyotavantech.com/forum/...highlight=horn
