- 0
HOW TO ..RACK AND PINION REBUILD
ANY HELP WILL BE VERY WELCOME
I am reassembling the rack and pinion ( 86,LE ) and forgot what direction does the GUIDE, RACK END go in !!!
it has a slightly wider lip and holes in the opposite end,, the exploded view shows it goes into the rack cylinder before the end oil seal... and then the STOPPER, CYLINDER END .. i hope this is correct. the exploded view is also showing two oil seals at the control valve end.... ?
i only have two oil seals not 3 ,, no sure why the illustration has two 44253A= Toyota Part #90999-99132 SEAL, OIL (FOR POWER STEERING RACK HOUSING)
Reason: added pics
- 0
Re: Another Rack inquiry, maybe with a little twist
i think i got !!!
