Results 1 to 2 of 2
Thread: NLA Part Numbers, Interchangeable Part Numbers, Alternate Part Numbers (A List)
    "Hansel" The 1988 5 speed 4x4
    Jan 2015
    Ojai
    Hi All,
    Lately we have been finding an increasing number of Toyota Vanwagon parts becoming no longer available (NLA). But I have had some luck using alternate parts from other Toyota Models or universal parts made by manufactures like Napa. I did some searching of this site and was not able to find a thread that covers this topic. I would like to propose a thread that members can post the NLA part number and description and the alternate part number and description that was successfully used instead. What do you all think?
    For example:
    No longer available
    Description: Toyota Vanwagon EGR VACUUM MODULATOR Assembly
    Part Number: 2587061011
    Alternate Part
    Description: 1997 Toyota Land Cruiser 4.5L L6 EGR Vacuum Solenoid
    Part Number: Standard Motor Products VS93
    ___
    No longer available
    Description: Toyota Vanwagon STEERING RACK NO.1(FOR POWER STEERING) BOOT
    Part number: 4553528010
    Alternate Part
    Description: NAPA Rack and Pinion Boot
    Part Number: NCD 2691647
    86 Van LE
    May 2022
    Netherlands
    Re: NLA Part Numbers, Interchangeable Part Numbers, Alternate Part Numbers (A List)
    No longer available
    Description: Toyota Vanwagon bracket,engine/transmission mounting, rear
    Part number: 12303-54010
    Alternate Part
    Description: Hi-ace engine mount
    Part Number: Toyota 12380-30010 / FEBEST TM-KDH200RR / FEBI BILSTEIN 171848
    It is not exactly the same. the hole for the bolt is a larger diameter, but you can either use a larger bolt, or a bit of pipe as sleeve.
