Results 1 to 3 of 3
Thread: 1993 YM65 4x4 Townace Camper Lift
    1993 Townace Camper 4x4
    Mar 2024
    Vancouver
    Hey I'm hoping to find someone on here who has already done this lift, I think it's pretty generic for these, but I'm in Vancouver Canada and most shops won't even look at this thing let along provide any type of advise.
    I've already added the Grabber AT's and maxed out the front torsion bar, worked great after a little fender modification. The back now looks like it's sagging and I need to add a 2" block to the leaf spings. I'd also like to change/upgrade front and rear shocks to some Bilstein.[ATTACH]12551
    86 Van LE
    May 2022
    Netherlands
    Re: 1993 YM65 4x4 Townace Camper Lift
    Oh wow, that is one amazing little camper!
    wouldn’t an add-a-leaf work? Or a longer shackle, if you do not want the suspension to get any stiffer. Or both
    Mar 2024
    Vancouver
    I did the leaf springs when I first got it because they were saggy and don't want to go any stiffer. I finally found a shop that will level it out with a 2" block which is possible because it's sitting on top of the axle.
