I have been getting a metallic smell while climbing big hills, it can and will accelerate up steep hills on the highway in 5th at any speed over 80KPH
but the longer the hill the more it smells.
Lately, I've noticed the same odour while cruising on the highway but much less prominent, it is only evident with the windows down (summer driving) so I don't really know if it has always done that or not (winters here are very cold and the heater really sucks)
This has been a long standing issue that hasn't been corrected by any of the other repairs.
To date (working backwards)- timing chain & gears, tps and full throttlebody cleaning, O2 sensors (both), cat, cap, rotor, wires, plugs and a pile of other stuff I am probably forgetting, like fusible links, air filter, various grounds.....
The only code it ever throws is 12 (no "NE" (rpm) signal to ecu after 2 secs of engine has been cranked)
I do have the dreaded intermittent no start (click, click, click), it will eventually start by rocking the clutch pedal till it starts to crank.
Usually though by the time it does, it has pumped enough gas through so it cranks a long time and takes a moment to clear it's throat.
I only ever see that code after one or more of these incidents.
Many things have been done to alleviate that condition, but none have had any lasting joy.
I have assumed that that is the source of my code 12 but just to verify I did pull the ecu and follow the diagnostic.
I do indeed have voltage (0.84) between IGT and E1, (spec is >7-1.0V) and it passes all the other tests on page FI-33.
I am guessing I am running a bit rich under load or suffering from insufficient advance.
Back before the timing chain was replaced, I had to crank the timing to 16deg to pass emission and I thought the smell seemed a bit less.
Once the chain went in I set it back to 12deg and have been smelling it ever since (but only on long hills)
(the timing does jump to 20deg when the jumper is pulled so I assume the timing is advancing correctly)
Aside form the smell, it runs like a top and the mileage is decent, I am averaging about 10.5L/100km (23mpg US) in mixed driving and I rarely do less than 120K (70mph) on the highway so I consider that to be fair consumption.
The only other suspect issue I can find is that the engine seems to run a tad cool (just left of centre - the needle just touches the edge of the wiggly water line and rarely goes higher) it does have new stat, water pump all hoses and a recored rad and the coolant has been flushed twice and is filled with Toyota Red.
I did notice it is missing the lower shroud so by rights it should run a little warm, clutch fan quiets down after a few seconds and I don't believe I hear it when it is hot, so I suspect it is functioning fine and not causing over cooling issues.
What I don't know is if the running temperature is enough to make it run rich or not??
I do have a slight carbon buildup in the tail pipe but just enough to mark you finger with a wipe, so it isn't a heavy deposit and it doesn't blow smoke.
I suppose there is a small possibility that it is distributor related as when I got Red, it really didn't like wet weather.
I found the dist cap was held on by 1 screw, which of course broke as soon as I touched it, the other 2 were already snapped off.
I did pull the dist. and clean it all up and drill and rethread the mounting holes and all seemed okay, but I suppose I may have missed cleaning a connection or 2, I don't remember if I cleaned up the electrical connections in there or not?? but as it ran well I haven't gone back there.
It was also missing an O2 sensor and the cat was toast, so while all the repairs have produced improvements, I have no baseline to compare to.
It is NOT insured for fire loss so that isn't an option.
I really need to solve this as I like driving with the windows down, and I am sure it isn't good for it in the longterm.
If anyone has any ideas I am all ears.
