Results 21 to 38 of 38
Thread: Engine Oil
    Re: What kind of engine oil?
    Okay, California, over 100 deg, makes sense now. Might make sense to run 20-50 in the summer time, but I expect you'll be getting into the frigid 60's in a month or so, so IMO 10-40 is probably still the better choice. If however your oil pressure is low, you may be able to benefit from a thicker oil. Typically low oil pressure is caused by worn or loose bearings. Unless there were extenuating circumstances I wouldn't expect replacing the oil pump to improve this. Did replacing it improve your oil pressure?
    If there's a question of oil pressure, I would install an aftermarket oil pressure gauge with numbers & get actual readings before switching oils and/or doing major work. Tim
    Forum Newbie XxCisnerosxX's Avatar
    1987 Toyota van LE automatic (painted like the mystery machine)
    Aug 2014
    Gilroy
    I actually haven't driven it. My heater core was also leaking and I managed to get the last one in the west coast for my van and the mechanic stated it was "too big" and the tubes that are straight needed to be curved. He opted to but some blue devil into it and yesterday I was with him when he did and the van started dripping water under the driver seat. I'm gonna pick it up later today and hopefully nothing is dripping
    1986 5 speed passenger, 88 Cargo auto
    May 2015
    Southern CA
    Which oil weight do you typically use? Good year round application?
    Is a 10w-30 appropriate, or too thin for warmer weather?
  4. 05-28-2015, 07:11 PM
    Reason
    no longer relevant
  5. #24
    Re: Which oil weight do you typically use? Good year round application?
    Personally I stick with 10w30.
  6. #25
    Van Addict AD2101's Avatar
    Tucson, AZ
    10w 30 here as well. I use it year around too and haven't noticed any negatives running it in the 100 degree plus heat. I don't see why moving up to 10w 40 would hurt in the summer months if you're concerned, but I don't see any need to.
  7. 05-29-2015, 08:36 AM
    Reason
    no longer relevant
  8. #26
    I know there's more, but here's what a quick search revealed for me:
    http://www.toyotavantech.com/forum/s...for-new-owners
  9. #27
    May 2015
    Southern CA
    Thank you Tim, much appreciated.
  10. 05-29-2015, 04:24 PM
    Reason
    no longer relevant
  11. 05-29-2015, 04:35 PM
    Reason
    no longer relevant
  12. 05-30-2015, 01:41 AM
    Reason
    no longer relevant
  13. 05-30-2015, 09:17 AM
    Reason
    no longer relevant
  14. #28
    1984 Toyota Van 2WD
    May 2014
    New York
    1984 Van bought new.
    20W50 summer
    10W40 winter
    500,000 miles
    John
  15. #29
    Here's a quote from one of the threads I linked to above:
    Personally I think 20w50 is too thick for the van. I might make an exception in a warm or hot climate IF the engine was worn and couldn't maintain enough pressure otherwise. If you have any doubts about oil pressure, rig up an oil pressure gauge and take the guess work out of it.
    Having too thick of oil can actually starve your engine for oil. If this oil is too thick you may not get enough volume through to the bearings and other small passages. Another potential problem is the pressure relief valve on the oil pump. If pressure gets too high, the relief opens and spills the excess oil back into the pan (instead the pump pushing it to the places it's needed). Tim
  16. #30
    Skamokawa, WA
    I tried 15W-40 and the camshaft bearings started whistling at about 2800 miles. I changed it to 10W-30 Full Synthetic and it's been fine ever since. Just follow the user manual. If your engine is pretty worn, 10W-40 should be fine.
  17. #31
    May 2015
    Southern CA
    Thoughts on using oil with higher zinc (ZDDP)?
    This has been a bit of a hot topic on some forums. What are your thoughts on using oils with higher ZDDP in our beloved vans?
    Most off-the-shelf oils are now in the 800 PPM range, down significantly from the past. Is our engine design one which would benefit from seeking something higher? Or, is it really a non-issue here?
    What oil do you use?
  18. #32
    Re: Thoughts on using oil with higher zinc (ZDDP)?
    Oil is quite frequently a hotly debated subject on forums. I don't know anything about the argument on ZDDP & due to hype & misinformation I doubt anybody really does. Based on the arguments I've followed in the past, it's my belief that most of these "magic potions" are just marketing techniques. Rather than admit they got duped, most people will exaggerate their experiences and swear by said products.
    Bottom line? Make sure it's got oil in it. Unless there are special circumstances, stick with the type and weight recommended by the manufacturer. Brand probably doesn't matter much. As for me? I prefer to run synthetic (currently using Royal Purple 10w40). Synthetic is expensive though and due to that I will only use it in vehicles that do not burn or leak excessive amounts of oil. For those rigs I get gallon jugs of the cheapest stuff I can find. Thankfully I no longer own any vehicles that burn oil. As a result all my rigs are now running on synthetic. Tim
  19. #33
    May 2015
    Southern CA
    20w-50 oil for these vans?
    I just picked up a new van. Miles are around 150k.
    There's a sticker on the windshield indicating the last oil change was with 20w-50. Is this an acceptable weight? Or, should I drain it?
    Thanks.
  20. #34
    1988 4WD LE 5 spd mnl
    Oct 2013
    so cal
    Re: 20w-50 oil for these vans?
    Congrats on the van. The manual states that's OK to use. But personally I only use that if it's on sale and the hot months of the year. Normally I grab 10w-40. I'm not an expert but with my van I just find it sounds a bit better when I run 10w-40.
  21. #35
    May 2015
    Southern CA
    Quote Originally Posted by ratatouille View Post
    Appreciate the response. And thanks. Glad to know it's at least in the manual. Once the summer has past I'll also be doing 10w-40. That's what I would have guessed.
  22. #36
    1987 4WD Automatic
    On the outskirts of Mordor
    Several years ago Timsrv postulated that 20w-50 oil might be too thick and have trouble getting thru
    the oil pump screen at the bottom of your motor, thus giving you a constant oil pressure trouble light.
    I actually experienced this, so I went back to using OEM spec 10w-40 oil.
  23. #37
    (2) 1989 2WD LE VAN Wagons
    Jan 2011
    I have run 20-50W where temps are consistently over 80 degrees in my past Vans that had high mileage and with especially worn guide valve seals which reduced the amount of blue smoke on acceleration due to thicker viscosity
  24. #38
    '87 4-WD 5speed window van wagon
    Jul 2017
    near tomah wisconsin
    i ran castrol syntec 20w50 for approximately 100,000 with no issues. last oil change (5k ago), i switched to 5w50 castrol full synthetic. it's a little spendy @$9.67/quart, but i am a synthetic believer.
