Results 1 to 20 of 26
Thread: Suspension questions
    Dec 2010
    Rockville, MD
    Im in the process of trying to add a little more life to my suspension. My van is an 86 with 327,000 miles is still on its original springs and my mechanic told me not to change them but instead change the rear shocks and add heavy duty ones instead of the Toyota OEM which are not available anymore. I called toyota and the springs are still avail but my mechanic said your better off just changing your shocks even though the springs are still original. I plan on also changing my front shocks and my mechanic also added that he would not feel safe adjusting the height of the van by the two bolts that adjust it just incase something breaks or bends. Im sick and tired of moving all over the place whenever I take a turn or hit a bump.
    My questions are, what shocks would you recommend for the front and back?
    Also how difficult is it to change the upper control arm bushings? They are noisy. Also which ones should I buy? My mechanic says I may get some stability by changing them.
    Re: Suspension questions
    Measuring ride height will tell you if you have an issue with springs.
    They may be fine, being NLA makes for an easier decision, though.
    You should verify availability, do a little legwork online.
    I know, for a fact, that the rear shocks are available, I ordered rears for my 4WD and they supplied the 2WD variant.
    They are going cheap if you want them.
    As for heavy duty, KYB is probably a good bet, hopefully someone else will chime in.
    Van Fan wirewrkr's Avatar
    Apr 2012
    I always liked the KYB gas shocks for "saggin' waggins"
    Van Fan RawbSpear's Avatar
    87 4wd automatic
    Marin CA
    is your an 2 or 4wd?
    Apr 2012
    Mines a 2WD
    Dec 2010
    Rockville, MD
    Mine is a 2wd. I'm probably going to go with the kyb's front and back and I will also look into replacing my front upper bushings if Toyota still offers them. With everything running good I feel as this maintainence will be essential in my goal to break 400k.
    88 4x4 5spd
    Jun 2012
    Seattle
    Has anyone considered getting custom springs made? I have found a few places online, but I don't have any info on the van springs to supply for a quote. I was hoping to incorporate the 2.5" of lift I want on the rear, instead of relying on Mr. Gasket.
    I am running KYB's all around on my 4x4 and I like them.
    Dec 2010
    Rockville, MD
    I just got my bushings in and plan on having my mechanic do them next weekend. I will post pics of how the original ones look compared to these after 26 years.
    Van Fan davidgracevan's Avatar
    1989 Toyota Van LE 2WD A/T
    Nov 2011
    Philippines
    is gas type better than the fluid type shocks?
    In a word Yes. In reality all shocks are hydraulic (fluid filled), but a gas charged strut has a gas chamber as well.A strictly hydraulic shock will dampen movement only, whereas a gas charged unit will want to increase to maximum travel.When installed it is always somewhat compressed, and will provide a slight increase in ride height compared to non-charged shocks,they will also improve the dampening ability of the shock. OE shocks were gas charged, it is always better to stay with the same caliber or better, downgrading is not recommended.BB
    Dec 2010
    Rockville, MD
    Started doing the upper control arm bushings on my van today with my mechanic. To me and him it is definitely not an easy job. We were able to do the right side which took almost 4 hours by itself. Once we started to do the left side the torsion bolt was stuck and started spinning. We may be in trouble here, any advice from someone who has done the job before will help.
    Dec 2010
    Rockville, MD
    Finished the upper control arm bushings tonight on the left side. So now both sides are done. It is easier to access the bolts to remove the control arm from the engine bay instead from underneath. Van rides pretty smooth.
    Dec 2010
    Rockville, MD
    Whats left of the upper control arm bushings on the right side. The left ones were even worse (didnt picture them)
    Lol, I suspect there's quite a few vans driving around out there with similar looking bushings . Tim
    Dec 2010
    Rockville, MD
    Given that it is such a difficult job I would have to agree.
    Van Fan foreverly's Avatar
    1987 2WD
    Dec 2012
    ATX
    So Mahleek - what method did you use to do the bushings? Brut force? Or did you take them to Toyota?
    Dec 2010
    Rockville, MD
    I bought the bushings from toyota but my mechanic used a tool that connects to an air gun which is kinda like a high powered chisel that pushes them out. I dont know the name of that tool maybe someone can help me with that but thats what we used to knock them out
    1988 Toyota van LE
    Mar 2019
    Vancouver
    Are the upper control arm bushings NLA? I only see "front lower" on RockAuto.
    (2) 1989 2WD LE VAN Wagons
    Jan 2011
    Quote Originally Posted by Wrench View Post
    48632-27010
    Upper still available from Toyota $30 2 required
    48632-28030
    NLA
    1988 Toyota van LE
    Mar 2019
    Vancouver
    Quote Originally Posted by JPERL View Post
    48632-27010
    48632-28030
    NLA
    Is the NLA part the arm itself?
