my positive connection failed and melted the little black terminal box.............I cut the two eyes off the wires ,stripped about an inch of wire jacket off and used a splice cap/marrette .....a big blue one and packed a little blob of silicone in the end......ask an electrician for one maybe......pre twist the wires together first before twisting on the cap
Did you read the other thread? What was the charge voltage on the other alternators while they were functioning??? Is there a power steering leak getting on the alternator? Are you using a genuine Denso alternator or one of those cheap aftermarket rebuilds? I'd also recommend searching the site for the thread "alternator woes" and read. Tim
