Hi! Thank you so much for taking the time to read this and any input at all is beyond appreciated![]()
I am having two leaks underneath my van (1984 Toyota Vanwagon), right under the front wheels. The one thing we do know is that they are both leaking from the coolant system.
_______________________________________________
1. The first one, we call the "Mystery Metal Hose" is here:
Click: http://postimg.org/image/wwrq33lmp/
Click: http://postimg.org/image/gu95k0ie9/
Questions:
First of all, what is it?! What does it do? How does the contraption hook to the engine?
Do you happen to know what the connections are on each end? I'm not sure if they are copper ferrule or a gasket or what it is! It is leaking from the coolant system. It seems to come from the lower nut in the pictures above. After I drive it for a little run of about 30 minutes, it is leaking.
2. The second one, we presume it is "Assumed Heater Hose" is here:
Click: http://postimg.org/image/6nqg6k8er/
Click: http://postimg.org/image/vxzgi909f/
Questions:
We are assuming since it is going toward the rear of the car, we are assuming it is a heater hose? Is that correct? If not, what is it? It is also leaking from the coolant system.
Any and all information is beyond appreciated. Please feel free to correct the terms, we would love to know what the Mystery Metal Hose is and if we're correct about the Assumed Heater Hose too!
Thank you SO much for ANY help!!!!![]()
. I would recommend a good draining & flushing of the cooling system, replacement of any questionable rubber hoses, then refilling with new antifreeze. Hopefully the previous lack of maintenance hasn't taken too much of a toll on other things yet. Tim
Tim's undoubtedly correct; I was (foolishly) distracted by the statement that the pipe was truly leaking. The pipe I was referring to is nearby. For your peace of mind, you can easily confirm which it is by finding out if rubber (heater!) hoses are connected to it. Rubber hose connections (in this area) using hose clamps = coolant system pipe. The EGR pipe has (if I'm remembering this correctly) a hex bolt on the lower end (closest to the viewpoint of the photos posted).
