1996 Previa LE S/C 2WD, 314k miles
I have a leak from the distributor shaft seal (not the o-ring, I replaced that). getting oil leaking into the distributor cap and down to the exhaust.
I found a seal kit online and am trying to get the distributor apart to inspect/replace that seal. I have replaced these before in my Hondas, where you just knock out the pin that holds in the doohickey that keys to the camshaft, then the shaft slides out and you can get to the seal. However, I've pushed that pin out on the Previa but it seems there is something else holding the distrib shaft in place. It has just a little play, almost like there is a snap ring somewhere, but I do not see one. I have the factory service manual but it does not detail how to get the distributor apart, only how to remove/replace it. Does anyone know the secret to getting these things apart? Would love to not have to replace the entire distributor, especially after getting the seal kit.
Thank you!
