30" tires and power, Aerostar springs
I remember reading over on TVP that folks fitted 30" tires with some fender mods.
I'm curious how much power was lost?
What was the RPM change?
I'm currently on 27"s that need to be replaced soon. Debating getting 15" rims for more size options.
thoughts from the experienced?
How to install Aerostar (aftermarket) springs?
Thinking through my van lift. Interested in using the Aerostar springs.
Can anyone tell me how much I need to trim the springs? Or any info on the installation process?
thanks!
Re: How to install Aerostar (aftermarket) springs?
I am also curious if people are able to use the van spring insulators with the Aerostar springs. I am trying to decide between getting Moog CC845 and cutting them or getting the daystar spring boosters
i have the moog aerostar springs and cut the top 2 coils IIRC. I would do one and see if its still to long then cut one more coil just to be safe. i borrowed my neighbors angle grinder and he actually cut one a hair too short but we were fortunately able to make it work. Im not using any spring insulators since paper thin OEM ones were toast so its metal to metal which isn't ideal but it hasn't presented any problems since i did it about 6 months ago. Highly recommend this mod over spacers as you get the greater travel and its not really any harder all you need is an angle grinder or something to cut the spring with. the lift height is perfect for my 215/75/15 tires (sidekick wheels) and the tacoma bilstein shocks. nice ride too.
fitting 30" tires will require significant modification to the suspension, as well as cutting up the floor pan and door/frame. i just met a new user on here, VanCo, last night and he showed me his rig which had 30" hankook dynapro tires. it was amazing.you could ask him about it if you're interested. however, the work he put into getting the lift and room for those tires was....well....lets just say significant. i think 215/75/15 with the longer springs and cranked torsions up front is a pretty good setup but i may be biased :)>:
