Results 1 to 9 of 9
Thread: rims on tv
    1989 Toyota van
    SAN ANTONIO
    rims on tv
    how will 15x8 0 offset rims on 195/50/15 tires look on a 89 tv..does anybody have pics? wil they rub? show them off
    Re: rims on tv
    They may bolt up but would stick out too far (about 2"). Those are very low profile tires though, I suspect they would rub, but that's hard to determine without a trial. I wouldn't expect the sliding door to open (would hit the R/R tire). Tim
    1989 Toyota van
    SAN ANTONIO
    Re: rims on tv
    yeah I thought about that the reason im asking is that its time to buy new tires for my tv I have a corolla just sitting here so im thinking of trying them on the van but thanks for the fast post
    1989 Toyota van
    SAN ANTONIO
    Re: rims on tv
    Ok so I got around to putting on the 15x8 and they fit real nice look great no rubbing what's so ever I just can't open the side door... To good to be true right is there anybody in the forum that has the fix for this problem? I know I've seen some previas with a door extender is there one for the old tv? Please help it looks to clean on the rims and tires way better then I expected so I want to get it going thanks in advance
    Re: rims on tv
    I'm not sure what it entails to extend the door on a Previa, but the slide mechanisms on our vans are very similar. I would think you could retrofit that extender on a van door.
    1989 Toyota van
    SAN ANTONIO
    Re: rims on tv
    Ok ok do you know where I can buy one??
    Re: rims on tv
    No, I didn't know they were available until you mentioned it in your previous post. Maybe the Previa guys made them?
    Aug 2012
    Tacoma, Wa
    Re: rims on tv
    Here's a thread covering fabrication of the Previa extension you are asking about. Something similar should work for the Van. Thttp://www.vipstylecars.com/forums/s...a-sliding-door
    Re: rims on tv
    Nice. This is what makes forums so worth while. So much knowledge to be shared! Score on this one. Thanks Original! Tim
