Results 1 to 11 of 11
Thread: Rear Seat Situation
    Forum Newbie Justdrumin's Avatar
    1985 Toyota Van Le
    Oct 2014
    San Diego
    Rear Seat Situation
    Currently the rear portion of my van looks like so:
    The previous owner gave me the seats that came with the van but they're pretty destroyed
    I picked up some seats off of craigslist from a 1986 which look like this
    However the situation arises when it comes to mounting.
    The old seats mount with what appears to be 8 bolts:
    And the new seats from the 1986 appear to need some sort of quick release track?
    Close up:
    Does anyone know what I need to mount the new seats?
    Dec 2010
    Nashville,tn
    Re: 1985 Van Rear Seat Situation
    Looks like your van came with factory seats, then someone put in aftermarket seats. The small divots inboard of the wheelwells should have small bars that your newer seats lock onto. So far as i know 84 85 seats and 86 and up are the same in the rear
    1985 Toyota Van Le
    Oct 2014
    San Diego
    So it seems I just need to source those bars? Do you know if they're available NOS or aftermarket?
    Dec 2010
    Nashville,tn
    I imagine you will only find them in junkyards. I took a pic but cant post from mobile
    1987 toyota van 4x4
    Apr 2014
    portland oregon
    toyota van seats
    I have a 4x4 and a standard van that I got seats from other vans. The floor in both vans look like this and the seats bottom look like the 2nd picture. Is there an adapter I have to get or do I have the wrong seats and have to get them modified? Either way would love to hear back on how do I make the bottom of the seats fit the interior.
    Thank you
    Re: toyota van seats
    It's hard to tell from your pictures but the bench seat vans and the captains chair(middle row) have different connections. Also the conversion vans have a whole other custom interior depending on the conversion company.
    1987 toyota van 4x4
    Apr 2014
    portland oregon
    Yes, sorry the photo isn't great. If I run out of ideas I might take it to a Van shop in Portland Would love to hear other feedback when possible.
    I would need more information to know for sure (VIN would help), but it appears to me that you have a cargo conversion van. Cargo conversions are "bare bones" cargo vans sold to aftermarket conversion companies. These companies would then build custom interiors, add windows, custom paint jobs, & other accessories then resell. Back in the 80's There were many such conversion companies but their popularity dwindled over the years and most have since gone out of business. Today the problem with these vans is availability of replacement parts. Many parts were custom built and/or purchased from outside aftermarket vendors. Even back then these were "very limited" production runs and parts are all but impossible to find today. This means you won't find "plug n play" parts but if you're handy you can repair/fabricate as required. You can convert by taking seats from junk yard vans, but it's very unlikely you'll find things that mount the same way. You will most likely need to fabricate, drill holes, bolt, & weld to make seats from other vans mount safely. Good luck. Tim
    1987 toyota van 4x4
    Apr 2014
    portland oregon
    Thank you guys and Tim you are right there are many configurations. I did take your advise and im going to do a total modification (welding bolting and such) to be able to use a middle and rear bench seats out of an LE into a cargo van.
    Once I started to take the carpet off and I came upon this steel bar come across the can floor.
    What is interesting is that same bar is right over the area where normally you would drop in your seats on the LE. I thought it was because of the 4x4 option and that it would give more strength to the floor.
    Then I checked my 2wd van and found the same bar going across that same area.
    Which leads me to believe that Toyota did not want people taking seats from a NON LE version van and installing it in a cargo van because there are no seat belts installed in the non LE versions.
    My questions..... To anyone's knowledge does that bar picture here serve any other purposes then the conclusion I came to? I do need to remove it in order for me to install the seats! Please advise
    Toyota Van
    Jun 2015
    LA
    You can make adapters out of 2x4's and cover them or paint them. The seats sit 2 inches higher but it works great in my van.
    Toyota Van
    Jun 2015
    LA
    Ripping apart my floors today in my 4x4 (captains chair van) just as I was about to modify the floor to fit the bench seats I found these. Bench seats fit right in. I don't have that metal bar.
