I suppose it could leak from any of the seals, but the other common spot I've found is the o-ring that seals the flow control port on the engine side of the pump. It's too tight to access with the pump installed, so the entire thing will need to come off before you can change it. Since it's tight quarters here, it's even hard to verify a leak from this port with the pump installed. If the fluid is leaking down the engine side of the pump and then dripping on the alternator, it's a pretty safe bet that this is the spot it's leaking from. Once the pump is off you'll need a small set of snap-ring pliers and a small screwdriver. Slightly depress the flow control valve cap with the screwdriver (to relieve pressure against the snap-ring), then remove it using the snap ring pliers. The cap has a spring pushing against it and it's easy to lose parts if the spring launches the cap. The o-ring goes in the groove that runs the periphery of the cap. Here's an illustration. Tim
BTW, the o-ring on the suction port (previous post) is Toyota Part #96711-19013. The o-ring on the flow control port cap (this post) is part #96711-19014.
Here's a couple other power steering related threads:
https://www.toyotavantech.com/forum/...g-system-noise
https://www.toyotavantech.com/forum/...alot-of-fluid!
