Results 1 to 13 of 13
Thread: 86-89 toyota van rebuilt transmission
    Toyota Van
    Jun 2015
    LA
    86-89 toyota van rebuilt A44DL transmission
    I have a transmission for an 86-89 Toyota van I bought for an 85. We put it in and couldn't get it to work in the 85. It doesn't have a torque converter $200 obo. This is a totally rebuilt trans
    Re: 86-89 toyota van rebuilt transmission
    I am curious as to why it wouldn't work.........please elaborate.
    Toyota Van
    Jun 2015
    LA
    To be honest I have no idea I know nothing about the internal of an automatic transmission. I towed my van to a transmission shop and I didn't even tell them it wasn't the exact right transmission and I got a call a day later and they told me this isn't the right transmission and its not going to work.
    85 2wd 894wd
    duncan bc canada
    Quote Originally Posted by vanalogs View Post
    mighty weird . i swapped a trany from an 1985 into a 1988 and then a few years later installed the 1988 back into the 1985.............its a long story...
    Some shops (most actually) don't like installing parts supplied by the customer. On something like a transmission, they make most of their money by rebuilding or supplying that for you. I'm not saying that's what happened here, but it smells a bit fishy. The only other thing I can think of is the eBay seller sent you the wrong transmission.........although the one in your picture looks right. FYI, all automatic 2wd van transmissions from 84 - 89 are interchangeable. If they installed it but it didn't work I'd say you got a bad and/or misrepresented transmission. Tim
    Toyota Van
    Jun 2015
    LA
    Yea I don't know what the deal is I originally thought it was a bad transmission because it didn't shift into gear when my dad and I put it in then took it to the shop and they opened up said it was fine but it was just the wrong trans. If anyone wants to come check it out just PM me Ill be more than happy to let you mess with it.
    89 Cargo Panel AT 85 Cargo AT
    Jul 2013
    N VA
    FWIW I also have an 85 Van and bought one of these remanufactured transmissions off Ebay from transparts734. Worked out OK for me w/no compatibility problems and have driven about 1K miles on it so far.
    I'm fortunate to have a small garage around the corner from me that is familiar with these vans and my 1st gen MR2s.
    Maybe a different mechanic is in order?
    Good Luck
    Dec 2010
    Rockville, MD
    Quote Originally Posted by Van Damn It View Post
    Good Luck
    I got my transmission from the same ebay seller at a great price. 20,000 miles later still works excellent.
    Toyota Van
    Jun 2015
    LA
    Quote Originally Posted by mahleek87 View Post
    nice to hear its working for you maybe you should consider buying mine as a back up
    Jan 2016
    Red Bluff, Ca
    Is this a G53 transmission? If so I will buy it. Where are you located?
    Jan 2016
    Red Bluff, Ca
    Oops. I see your heading. Not a G53. And here I got all excited. Sorry.
    Toyota Van
    Jun 2015
    LA
    still available
    1987 le
    Jun 2019
    Utah
    still available
    I know this has been years but still have this?
