Results 21 to 32 of 32
Thread: Stalling Mystery
    Re: Stalling Mystery
    It's always a good idea to perform tests and follow the manual. I think it's an ECU because it's flashing code while running, but no code is recorded. Also that VSV is controlled by the ECU and it's freaking out. The ECU also controls the Fuel Cut RPM feature and based on a previous post you made I thought that was also acting up. Faulty input to the ECU can cause it do do strange things, but unless it's a power input, it would store code and retain it. Since it's not retaining trouble code(s) I'm fairly confident the issue is inside the ECU. Nothing special about replacing the ECU, just unplug the old and plug the "new" one in. Tim
    1987 LE Passenger Automatic
    Jul 2019
    Atlanta, GA
    Okay, so I attempted to locate an article on accessing the ECU on TVT but couldn't find one so I just dove in and removed the interior trim piece just to the left and behind the driver seat, only to find what appears to be body metal. Doesn't seem to be any kind of access panel to where the ECU should be mounted. My best guess is that I would need to remove the seat belt retractor and then reach up into the bodywork and pull the ECU out through the seat belt retractor hole. Am I on the right track here or barking up the wrong tree?
    Jul 2019
    Atlanta, GA
    I was right. I got the ECU out. Took photos of the process for the purpose of posting a How-To article if there isn't one on the TVT yet. Replacement part has been ordered from RockAuto. Spending less is always nice but when it comes to electrical/electronic parts, I feel much more confident in a remanufactured part with a warranty versus the risk of a functionally unverifiable pull-a-part. Anyway, should receive the part and know the outcome before the end of this week, and will follow up with results.
    I'm fairly confident it's your ECU, but there's not an easy way to be 100% sure until you swap it. Now that you have hundreds of dollars on the line I certainly hope I made the right call. My apologies for assuming you knew how to access. Here's a couple threads where that is discussed:
    https://www.toyotavantech.com/forum/...driving-87-van
    https://www.toyotavantech.com/forum/...1526#post41526
    Your PDF is awesome! Thanks for the contribution! Tim
    Jul 2019
    Atlanta, GA
    TIMSRV,
    You sir, R O C K!
    Stalling Mystery solved! It was indeed, the ECU. Got my ECU from RockAuto today. It actually arrived with a bent terminal in the 10-pin connector.
    But with my magnification lamp and some needle nose pliers, I got that terminal straightened out and the ECU installed. Engine fired up within less than one second on the first try and ran well. Absolutely no visible smoke from the tailpipe. Allowed the engine to idle until full operating temperature, then tried to invoke the problem but could not. Shut the engine off, allowed it to cool for a while, then repeated the test for invoking the problem but could not. Next, I road-tested it with no issues. Shut the engine off and allowed it to cool for a few hours, then road-tested it again to complete two drive cycles, with absolutely no issues. I can’t tell you how happy I am with this outcome. I am indebted to you. I am also very thankful to ‘PNW vanwagon,’ ‘JPERL,’ bikeregg,’ ‘trestlehed,’ and anyone else who responded to my thread. Everyone’s responses have been added to my Knowledge Base for future reference if needed. This was a challenging problem that finally ended in victory. Time for celebration! Thank you all. I just can’t thank you enough. I had big plans for this van cosmetically, car shows, etc. – which I can now pursue thanks to the help from you. I’m no expert on these vans, but I sincerely hope that I can help others in the same manner on this website forum. I have other minor issues, for which I will start a new thread IF needed. But as for the Stalling Mystery……this is my “signing off.”
    I think dancing bananas are appropriate here
    1987 4WD Automatic
    On the outskirts of Mordor
    PrecisionDriven, congrats on your victory!
    Also, I didn't know that Rock Auto is a parts source for ECU's.
    Good to know!
    Jul 2019
    Atlanta, GA
    Yes. RockAuto had them under the category of Electrical, AND will accept returns on this item. PartsGeek.com also sold the same exact one BUT accepts no returns on electrical/electronic parts, which I went with RockAuto.
    (2) 1989 2WD LE VAN Wagons
    Jan 2011
    No ECU's availiable for 1988 and 1989 Model Vans
    1987 4x4 5spd LE
    Dec 2015
    Southern Oregon
    Well I have been chasing a 'miss' issue for about 2 months on the '87 4x4 5spd 334k miles. At first only at speed, a flicker of the CEL and a momentary hesitation. No codes from the ECU. As I was still setting a baseline for this van I bought two years ago went ahead with plugs, rotor, cap and wires. No change - momentary flicker but no codes. Replaced ignitor - still no change. Drove it around for a days and finally pulled Code 11. Well knowing some about the PO maintenance prior to my purchase I was discounting the AC switch, TPS and Neutral Switch. ECU!! Heck of a jump and the last listed item for Code 11 but what made me try this first is I went nearly a month with the 'Miss' but never recorded a code. EBay Swan Auto had one used ( I don't believe a Cradooone rebuild is the way to go). Received today and put in. Run about 40 milers so far, multiple restarts, freeway and around town. Idle is more consistent on restarts also. Not missing at all. So there may be something to the aging of the ECUs when they do not record an event but you saw the CEL blink.
    Just this guy's observation and it may not be correct for you.
    SoORYotas
    Toyota 1989 Van Wagon
    Nov 2018
    Las Vegas NV
    I think it's a bad ECU (Electronic Control Unit). Get the number off your old one and use it in an eBay search. Hopefully you'll find one for cheap and that will solve your problem. If nothing else it's good to have a spare around and/or to use as a troubleshooting tool.
    1985 Toyota Van, Automatic
    Jul 2019
    Gadsden, Al.
    Hey, thats my picture with the clogged injectors! ive since cleaned them and rebuilt them.
    Also took my tank to a radiator shop to have it cleaned out, painted and sealed.
    She runs like a dream now!
