Results 1 to 5 of 5
Thread: valve cover torque
    Midwest/Southwest/Northwest
    valve cover torque
    I can't find numbers I trust on the net. Surely one of you has a service manual...
    Oh wait come to think of it I have the pdfs from the old Yahoo site. But they can be a pain to find info in so if you have it handy you might beat me to it.
    Re: valve cover torque
    69 inch-lb
    Yikes.
    91 Previa
    Jan 2014
    PA
    69 inch-lb
    Yikes.
    and 43 in-lb for the ignition cord support bolt, and 48 in-lb for the #2 (outer) cover. [p.EM-11 of the 91 FSM]
    Just a nut driver is all that is needed. That lets you feel the torque-up, without needing a torque wrench.
    (You probably don't have a torque wrench that goes that low anyway.)
    No I certainly don't have an inch-lb torque wrench. Not finding a spec I liked I had tightened them to only a couple ft-lb and had to go loosen and retighten them when i found the correct spec.
    actually my initial torque was almost spot on, within the limits of my torque wrench
