Results 1 to 3 of 3
Thread: running temperature question
    1984 2wd
    Apr 2022
    Washington State
    Hi,
    I'm a proud new owner of a 1984 van wagon. I'm looking for input on the temp of my engine. The needle on my gauge is usually around 55% and sometimes up to 75%. Is this normal? Should I be worried? I replaced the water pump and its still running a bit hot.
    thanks!
Size:  13.2 KBName:  thermostat.jpg
    May 2017
    Glendale, CA
    Re: 1984 toyota van
    If your van actually is raising in temperature that much on the dial (and it's not a bad dial or thermometer) then it definitely is something to worry about, and get under control.
    There are a lot of threads about the cooling systems on here with a lot of useful information. What I've mainly gathered is most of the temperature dials don't move until the van is already on the edge of too hot. Presumably to hide minor fluctuations in temperature from nervous drivers.
    I would try getting a digital temperature gauge installed so you know exactly how hot it's getting, and have the entire cooling system checked.
    (I don't know where the needle is supposed to rest in the '84 van, but on my MasterAce, it's right in the middle. If it moves up even a millimeter, I turn on the heater to dump some heat.)
    1984 2wd
    Apr 2022
    Washington State
    Re: running temperature question
    Did lots of digging and found the info I need.
    I can’t figure out how to delete this thread though. 😮
