Results 1 to 7 of 7
Thread: 4WD Radiator - Is the second radiator always in use?
Hybrid View
    May 2017
    Glendale, CA
    Hello all,
    So I have the second, horizontal radiator below my AC condenser. Is the second radiator always in use once the thermostat is open? Is there any valving or additional thermostat between the second radiator and the main radiator?
    '91 CR30 JDM & '91 CR27 JDM
    Aug 2019
    U.S.A.
    Re: 4WD Radiator - Is the second radiator always in use?
    As far as I know, that second 'horizontal radiator' is the evaporator for you air-con, not a second motor radiator, and they do not share fluids.
    May 2017
    Glendale, CA
    On my van, there is the horizontal AC condenser in the normal place, and directly below it is a second motor radiator. Here is the diagram for the second radiator.
    Aug 2019
    U.S.A.
    My learning curve just tipped back to vertical
    Jan 2017
    Tulsa
    I drained my whole system from the horizontal one, I feel if there was valving it would not have drained or refilled properly. Make sense?
    Vandi-
    Toyota townace 4wd 1992 2ct
    Oct 2022
    Queenstown Nz
    Anymore information on this? I seem to have the second radiator as diagramed but am trying to find out if it runs in series with the main radiator or separate
    1987 4wd 5spd
    Apr 2021
    Quote Originally Posted by 89MasterAce View Post
    Where did you find this diagram? I dont see it anywhere in my BGB or anywhere on toyotaparts.com. I also have a 4wd and theres no second radiator on mine.
