Hi,
This summer I have noticed my '96 Previa's AC doesn't really cool well. The curious thing is, in the first 5 minutes of operation when the van is starting from cold, it works pretty well, with vent temps in the 45F range. However, as the engine warms up, it gradually creeps up to 65-70F.
One day I did notice that if I leave the AC compressor off, it will blow slightly warm air even when set to full cool. Poking around a little further, I also noticed that the heater core pipes under the dash (and under that small plastic cover with 3 screws) were hot.
I did verify that the control cable tied to the slider was moving the heater control valve (on the left behind the coolant expansion tank) and that it seemed to be moving to fully closed. I even popped the cable off and pushed it manually but it didn't move, and the heater core still seemed to be getting coolant flowing through it as it still warms up.
My question is - is this normal operation and maybe I have some other issue? Or is the valve blown and letting too much coolant pass through when shut?
Thank you!
