I discovered my 1989 Van that I bought has the part of the fuse block with the two isolated fuses for EFI and cold start system missing. Everything works flawlessly. The previous owner said the cooling unit in the dash was replaced. The main fuse block is zip tied in place. You can see where the isolated compartment was snapped off from the main fuse block I am assuming the two fuses are in tact but just tucked away out of view. I see you cannot get a new fuse block anymore. Anybody have one laying around? The part circled in red is broken off and the fuses 19 and 20 are missing or hidden/relocated
