Results 1 to 20 of 27
Thread: Check engine light will not reset
    1986 LE Cargo van
    May 2017
    Portland
    86 2wd van
    I've fixed the issues that came up, disconnected the battery for at least an hour while installing a new starter.
    Light does not reset. Tried pulling the 10A ECU fuse as well and got nothing
    Anyone know what else I can do the reset the check engine light?
    1986 LE Cargo van
    May 2017
    Portland
    Re: Check engine light will not reset
    Well...i figured out I needed to pull the EFI fuseable link to lear check engibe light, but still no luck getting rid if it so i can test my fixes.
    Pulled battery cables off for a whole day as well and still nothing.
    Anyone got any ideas?
    Van Addict AD2101's Avatar
    Tucson, AZ
    Not to be that guy but, you are sure you fixed the problem, right? I can't say I've ever had your specific issue, but whenever I had a check engine light that persisted after disconnecting the battery it was because I hadn't actually got to the root of the problem. What codes was your van showing and what fixes did you do?
    1986 LE Cargo van
    May 2017
    Portland
    @AD2101
    Thanks for the response!
    The codes I got were:
    Code 4: Water temp signal sensor (REPLACED, working fine)
    Code 10: Starter signal (REPLACED, seems to be working well, but having issues with cold starts, looking into cold start injector, fuel pump currently to fix that)
    Code 11: Switch signal (could not figure this one out, any ideas?)
    Every other vehicle I've own resets the engine light when battery disconnected, so I just assumed it was the same on the van. I suppose that is not the case?
    Any thoughts on this greatly appreciated!
    Code 11 likely is caused by a bad or mis-calibrated throttle position sensor.
    Quote Originally Posted by BetsyBrown View Post
    The Vans' codes DO reset with the battery disconnected (I've heard variably that it needs to be 10 minutes or more; can't remember what the FSM says offhand). If you are still getting codes, you have not found the problem.
    Tucson, AZ
    There are other possible culprits for your codes, which are all listed in the FSM. Are you saying that, after putting all the new parts in and disconnecting the battery, that none of these error codes went away? 0 out of 3 ain't good, at least on the Meatloaf scale, I would look at the ECU and make sure everything is hooked up snug and there aren't any exposed/damaged wires or burn marks anywhere on the ECU board. It's also the one constant possibility across all your codes so it's worth a looksie.
    1986 LE Cargo van
    May 2017
    Portland
    Re checked codes and they are all coming up at again
    4,10,11
    This was after having battery and ecu fuse disconnected all night.
    So apparently I didn't fix the coolant sensor and starting issues. Will look into it today.
    Started to dig into code 11,
    Found good threads but the video where Tim explains how to recalibrate the tps isnt available anymore. Anyone have a copy they can post?
    On a positive note me and BetsyBrown just made a 10 hour roadtrip from Portland to lake Tahoe without any issues! Only that it takes me 10 min to cold start her...working on that one.
    Tucson, AZ
    This one?
    1986 RWD
    Nov 2015
    Hawaii
    Thanks for re posting this video. I saw it a while back and lost track of it as well.
    1986 LE Cargo van
    May 2017
    Portland
    Thanks for re-posting @AD2101 !
    I could only find some sketchy photobucket links ;)
    1986 LE Cargo van
    May 2017
    Portland
    Made some progress, no more code 10
    I changed the starter out bc Ive been having issue with it for a while. But that didn't really help or clear the code.
    However, today I was checking connections and noticed a connector on top of the engine block, to the left of the throttle body, was partially melted and loose. I cleaned it up got it re connected and code cleared...and my cold start issue seemed to have gotten better...
    Still trying to figure out which cable it is. Can't get a picture uploaded for some reason
    EDIT it is the connection to the cold start valve, it was loose and damaged
    1986 LE Cargo van
    May 2017
    Portland
    Regarding code 4, I am getting a normal temp reading on dash gague and sensor is new and has good resistance...no breaks in the wiring.
    I am assuming my ecu is good bc I was able to clear another code
    Any thoughts on code 4 and clearing it?
    Tucson, AZ
    Yea I was going to say I wouldn't worry about the ECU anymore if you were able to clear at least one of the codes.
    RE: code 4. Which sensor did you replace? The gauge and the computer use different sensors. The gauge uses a single wire sensor threaded into the cylinder head just above the distributor. The computer uses one threaded into the upper water outlet. Here's an image from another thread to help with the location. It's the one marked "temperature switch".
    1986 LE Cargo van
    May 2017
    Portland
    Replaced the temperature switch, I'm assuming there's something up with the wiring I'm not finding...
    On another note, the idle up switch in this picture is not wired up at all in my van. Just a nub...guess I'll be looking into this too. I don't even see a loose connection just the sensor with an open end staring up at me.
    Try searching these terms. These are all common problems discussed many times before. Temp sensors, wiring, and plugs get brittle causing them to break or creating bad connections. I've had to replace the temp sensor connector on one of my vans and probably should in the other. Part numbers are given in other threads for the sensors/switches as well as replacement connectors. Idle up switches are no longer available so when broken or non functional the wire is attached to ground.
    1986 LE Cargo van
    May 2017
    Portland
    Ive been searching and reading up on these issues for a few days now, apologies if i am repeating things but just not finding the answers myself.
    Found the idle temp switch here i think...based on a part number i got in another post
    https://www.toyotapartsdeal.com/oem/...428-20050.html
    What does this switch do? Should I be concerned about replacing it and running a new wire to it? Could this be the cause of my code 4?
    Ive been searching and reading up on these issues for a few days now, apoppogies if i am repeating things but just not finding the answers myself.
    Don't waste your money on that one as it won't change anything (especially this time of year). Here's a post I made on that previously:
    That switch (Pressure-up Temperature Switch) is worthless anyhow. There was a service campaign back in the day that replaced that switch with a lower temperature one. Very few vans had that service campaign completed, and now the new switch is NLA. You're better off to just cut the old connector off, then put an eye terminal on that wire and ground it out. I usually extend the wire and put in on the front stud of the intake plenum along with all the other grounds. Doing so will activate your "pressure-up" system for 2 minutes after every start. This will help combat the Heat Soak issue. Tim
    Here's a thread that further explains the "pressure-up" system of the van: http://www.toyotavantech.com/forum/s...ht=pressure-up
    1986 LE Cargo van
    May 2017
    Portland
    Thanks for the info Tim!
    So on another note all the codes cleared today after I cleaned all the connections, and gave the tps a couple light knocks with a hammer. It's a Christmas miracle
    I'm sure it's a temporary, lucky fix, so ill be changing the tps out soon to be sure.
    Thanks for the input everyone!
