Results 21 to 40 of 53
Thread: Oil Pan Removal and Re-installation
    1989 Toyota Van LE
    Jul 2019
    Baltimore, MD
    Re: About to Install Oil Pan
    I replaced my oil pan with the engine in situ, being that your's is a 2WD, I would think it would be a walk in the park to swap out, by comparison.
    I used FIPG and was happy with the results, didn't have any significant issues getting the pan back into place.
    Personally, I have no love of cork gaskets.
    They are far too easy to over-tighten and they not fond of excessive heat.
    PS - I put the FIPG on the pan, before getting it anywhere near the vehicle, it has a long tack time, not at all like typical silicone sealants.
    I attempted this yesterday and could not fully remove the oil pan because of the oil pump. Just a heads up to others! Not sure if it’s an ‘89 thing, the height my engine is at, or what, but what a wonderful surprise lol
    1986 Toyota Van 2wd
    Jun 2020
    LBC,CA
    Re: Oil Pan Removal and Re-installation
    Yo!
    Don’t be afraid to use your jack on the engine. Lift the engine up a few inches and it will give way to the pan.
    Also don’t forget the frame stiffeners.
    1989 Toyota Van LE
    Jul 2019
    Baltimore, MD
    yooo! that's a great tip. In an exhausted panic I did the FIPG upside-down on the engine then reattached the pan...horrible time, lots of cursing, and not too confident in the longevity of that seal. I'll have to try it again with this knowledge.
    One shouldn't be able to "just lift the engine a couple of inches"
    Now if you undo the mounts you can get an inch +/-, but you have to be careful.
    Its easy to crush things (above/around the engine) with that method, also the potential for stretching/stressing hoses and wiring.
    1986 Toyota Van 2wd
    Jun 2020
    LBC,CA
    Toyotavantech: Noooo you can’t lift the engine too much
    DIY mechanics: hahah jack go Uga Duga
    Well, I didn't say you COULDN'T, just that you shouldn't.
    If ya did and the engine moved that much, you may want to get some engine mounts ordered up.
    If they're in good nic, the engine should only move a fraction of inch before the chassis starts moving with it.
    Quote Originally Posted by Diy2k View Post
    Lol, and then professional mechanic go: hahah kaching kaching
    1986 LE
    Aug 2017
    Florida
    Greetings to all.
    Found a very bad oil leak coming from by oil pan. It was only coming out of the back left corner, the corner that is below the oil filter drivers side. Well you would thing this would be a walk in the park but........... the one12mm bolt that is in that corner where the leak is is positioned very close to the body frame where a socket wrench cannot be put on to tighten. Anybody have a tip on how to do this or do I have to lift the engine out, nope, not me.
    Here is a picture of the bolt
    MT - been awhile since I crawled under but IIRC, the frame rail shouldn't be that close to the engine.
    Is it possible that its the transmission stiffener plate, that is in your way?
    1986 LE
    Aug 2017
    Florida
    Hey buddy, I am not sure what a stiffer plate looks like. I will have to get under there again to look but if memory serves me well it is a big chunk of metal and not sheet metal.
    Will advisve
    mt
    They are cast iron brackets that bolt onto the bottom of the block, just above the oil pan.
    The other end attaches to the lower section of the bell housing.( like a 45 degree brace)
    They are often in the way, but easy enough to re&re.
    1986 LE
    Aug 2017
    Florida
    Yep, that is what they are for sure.
    What do you mean by saying "easy enough to re&re?"
    That's a new one for me
    Sorry, old shorthand.
    re&re = Remove and Replace
    1986 LE
    Aug 2017
    Florida
    Oh crap, am I slow or what
    Thanks buddy, will keep you posted
    1986 LE
    Aug 2017
    Florida
    Hey Burnboot:
    OK, well I did not have to take off the that piece but you were spot on. I was able to get around it to see the leak was coming from the oil filter housing where it mounts on to the block.Coming right out of the bolt there. I cannot seem to find anyone who even knows what this gasket/O ring is. There is nothing on the site about it. So I guess I will have to take it out and see what it is and punt. If you know anything about it let me know.
    Thanks again for all the help.
    Like this?
    Toyota
    VanYR29LVYR29LV-PRBEKEngine, fuel system and toolsOil filter
    Oil filter for Van YR29LV
    Here are parts you've selected:
    No PNC#
    (SUB)
    OEM part number Required
    per car
    Production period Name Applicability Please order in advance In stock
    01 15691 15691-71010 01 08.1988 - 12.1989 GASKET, OIL FILTER 4YEC..YR2#,3# 4.91 USD
    (SUBS) 15691-71011 01 4.91
    to 5.15 USD
    02 15691 15691-71011 01 12.1989 - 01.1990 GASKET, OIL FILTER 4YEC..YR2#,3# 4.91
    to 5.15 USD
    More than 1 spare part found. Please define it more accurately before ordering.
    Click on the part subgroup below to get genuine part numbers.
  17. #37
    hmmm, pic didnt come with :(
    That seemed to work tho
  18. #38
    1986 LE
    Aug 2017
    Florida
    That's it!!
    So it is a gasket and not an o ring.
    Looks like I will have to go to Toyota and get it.
    Thanks. will keep you posted
    1986 LE
    Aug 2017
    Florida
    Hey Burnboot:
    Well this gasket is nowhere to be found. Toyota cannot even give me a clue on when they can have one. My only idea is to make one. Have any thoughts on this? I check the site for this and found nothing. I will at least post a new message to the group to see if anyone has any idea how to solve this.
    Again, thanks for your help on this issue
    At this point, it may only be available as part of a set (lower engine set maybe??), if at all.
    That gasket is very simple and I would not hesitate to make a new one.
    As long as you use proper gasket material (most parts stores will carry something) you should be fine.
    Cheers
