Page 17 of 18 FirstFirst 123456789101112131415161718 LastLast
Results 321 to 340 of 343
  1. #321
    87 Toyota Van Wagon LE 4x4
    Aug 2022
    Carlisle PA
    coolant tube under intake/exhaust manifold
    Looking to ID this coolant tube - it goes from the water outlet on back of water pump under intake/exhaust manifold and feeds oil cooler and heater hose.
  2. #322
    That's Toyota part #16268-73060 Pipe, Water By-Pass No 1. Unfortunately it's no longer available. Your choice is to repair (welding/brazing) or to fabricate something to replace it with. If you're lucky you might be able to find a good used one in a salvage yard, but these vans are getting harder and harder to find in the yards these days.
    PS: If it's just only holes or pitting on nipples, but otherwise okay, you can replace the hose and slide it on farther, then move your clamp up past the damaged parts.
  3. #323
    Aug 2022
    Carlisle PA
    will try to weld it, one of the nipples snapped off.
    Looks like exhaust manifold is cracked as well - assuming there is no use welding it. Any advice on finding an exhaust manifold for an 87 4x4 auto?
  4. #324
    Exhaust manifold is part #17141-72010 and that was available up until about 1 or 2 years ago. The manifold can be welded, but if you want it to last it should also be stress relieved and then machined flat on the mating surface. Because the intake manifold uses the same nuts/studs, it's important the mount flange be the same thickness as the intake manifold (where the nut/washer contacts). So only very minimal material should be removed. If it requires much machining, then you may need to compensate by welding/grinding on the nut side to bring it back up to spec in those areas. Tim
  5. #325
    Aug 2022
    Carlisle PA
    Any ideas why my water By-Pass pipe is so much different than what's in the parts manual or others have in their vans.
    Mine has a whole extra pipe headed to the left around the engine - is this part of the auto trans?
    Highlighted parts seem to be extra?
  6. #326
    The pipe in your picture is from an automatic 4wd van. Those vans have a sandwich type engine oil cooler that gets it's cooling from engine antifreeze (fed by that pipe). Yours is Toyota part #16268-73060. That pipe without the oil cooler section (in 2wd vans and manual transmission 4wd vans) is Toyota part #16268-73011.
    Toyota doesn't show the extra pipe sections in their breakdowns, but if you were able to get a 16268-73060 it would have that extra pipe/nipples. Tim
  7. #327
    86 Van LE
    May 2022
    Netherlands
    Hi,
    I want to replace the bumpstops that are on the front lower control arms. I looked at the toyota epc data, to get the part number, and to my surprise, they were available and affordable. However when I got them, they look nothing like the ones that are on the control arms now. Are my old ones incorrect, or are my new ones incorrect? And if the new ones are incorrect, what part number do I need? And I guess if not available I could go for a universal one, but the size difference is huge, so I want to make sure i get remotely the correct size.
    These are on my van now:
    on epc data:
    but it isn't even remotely the same size:
    now somewhere else, in a completely unrelated topic on this site, I saw an exploded view, maybe from a maintenance manual, that looks very much like what I have now:
    I ordered 48305-30030, listed as BUMPER, FRONT SPRING, NO.1
    Could it be 48331-29055, listed as BUMPER, FRONT SPRING, NO.2 ?
    This one is on a bit of an odd location in the parts diagram, and there is no clear picture. But if this is the correct one, where should the NO1 bumpstop go???
    and this one: 48331-27051 is listed for a townace, but does kinda look like what I have now, but more ehm pointy, but I guess mine could have been pointy as well at some point in time.... But it has the two mounting bolts like mine
    https://www.ebay.ca/itm/394503684535
  8. #328
    Van Fan Tan Van's Avatar
    1987 Van 2-wd
    Sep 2014
    Milwaukee, Wis.
    try looking at bump-stops for a 90's ford truck or a 1969 Chevelle -- there's a close match out there somewhere
  9. #329
    Forum Newbie vintagecoffeeroaster's Avatar
    87 vanwagon
    Dec 2022
    Northern Cali
    I think I need a new one of these. Does anyone have one for sale or know where I can get one. I believe it’s called a injector resistor or ballast resistor, I have a 1987 panel van with a Y4-e
  10. #330
    1986 LE
    Aug 2017
    Florida
    I think that is the resistor network for your injector windings DC.
    Anyone out there that can confirm that?
    Mytoy
  11. #331
    Van Enthusiast 89van's Avatar
    Jul 2021
    Phoenix, AZ
    Yep, it is!
    Name:  resistor and efi stuff.jpg
  12. #332
    1986 LE
    Aug 2017
    Florida
    Nice Exploded view. Where did you get that?
    mt
  13. #333
    86 vw synchro
    Jan 2022
    San diego
    What is this I found this under the drivers side dash? The electrical fire definitely happened with a previous owner. I don't see any other damage under the dash. Doesn't smell like burnt electrical at all. Don't know if its related, but the solid core wire used to replace the 1.25b fusible link has some melty insulation, replacing that with bulk 12 gauge fusible link wire.
    I cant turn over the van with it uninstalled as I am currently trouble shooting "click no start" that went from intermittent to permanent. Dash lights are fine with the ignition switch powered on and the mystery box uninstalled.
Size:  13.0 KBName:  IMG_0101.jpg
Size:  19.2 KBName:  IMG_0100.jpg
Size:  20.2 KBName:  IMG_0104.jpg
Size:  11.8 KBName:  IMG_0105.jpg
  14. #334
    86 Van LE
    May 2022
    Netherlands
    Hmm kind of looks like this thing:
    https://www.ebay.com/itm/145562795633
  15. #335
    86 vw synchro
    Jan 2022
    San diego
    That is exactly what it is, thank you!
    Looks important. Ive been driving around for two years with the burnt one installed, just happened upon it troubleshooting something else, codes are all clear. I should keep an eye our for one with the correct P/N in any case.
    Edit:
    Looks like it is for cruise control. I was afraid it was the ATM control computer.
    https://www.thesamba.com/vw/forum/vi...380099&start=0
  16. #336
    86 Cargo • 5-speed manual
    Dec 2018
    86 5 speed manual caravan
    Does anyone know what part number this bushing would be? I think it's the shifter linkage bushing?
    I was driving the other day and it fell out which caused me to not be able to change gears.
    I put a washer and nut on to get off the side of the hwy but can't leave it like this.
    im also into alternative fixes
    thanks!
    Red circle is the missing part. next to it is an identical setup circled in green
  17. #337
    The rubber grommet halves are Toyota part #90480-17016 (they are sold separately, so you'll need 2). The washers (top and bottom) are Toyota part #94614-10800 (also sold separately). The nut is Toyota part #90179-08044. According to http://www.toyotapartsdeal.com all of these are still available......at least that's what they say now. Good luck. Tim
  18. #338
    Dec 2018
    TIM FOR THE WIN!
    You are a life saver thank you so much!
  19. #339
    87 toyota van
    Dec 2024
    USA
    Ok, here's another, I don't see it in my manual.
    First pic is a small thing under the air intake with and electrical connector and 2 hose ports, one port had a 6 inch hose on it that went to nowhere. The second pic is a small round thing at the top of the engine and has one open hose nipple. It doesn't seem like it would go to the small one under the air intake. Also doesn't seem to be in the EGR system. Thoughts? Thank you.
  20. #340
    Quote Originally Posted by felorod View Post
    Those are VSV's (Vacuum Switching Valves). Here's a link to a thread where their functions are discussed: https://www.toyotavantech.com/forum/...tached-diagram
