Page 1 of 4 1234 LastLast
Results 1 to 20 of 68
Thread: unhappy day
    97 Previa DX AWD
    Midwest/Southwest/Northwest
    unhappy day
    97 Previa DX AWD
    Re: unhappy day
    Well I guess my tie rod is the least of my worries now.
    First order of business is to get the radiator or shroud out of the fan. Then I can assess what still works and what doesn't. It runs and moves, I know that because I drove it from the flatbed into my driveway. The PS reservoir is broken with fluid everywhere. Oh well it needed a change anyway. Coolant system might hold coolant-although the reservoir was empty when I opened it nothing gushed out anywhere when i added water. I only saw a little coolant at the scene of the crime. Not sure if there is any hope for the ac core, I haven't tested if it held but it's sure looking sore. Tricky part might be hooking something onto the bumper to pull it out without damaging the core, if it isn't toast already, because those two are real cozy pals in the current state of things. Well on closer look I guess I can unbolt the bumper, if i can get at the bolts which are no longer behind their access holes. It's nice to know Toyota places styrofoam between the soft and hard bumpers, yessir that makes me feel very safe now. Airbags didn't deploy so that's a plus, or a minus, since they maybe should have?
    Gotta give lotsa props to my GT Styling bug guard, the cheapest lightest version, which will live to grace another hood. My previous, more expensive one shattered into 20 pieces when it fell off once. Yes, that bug guard is the star of this operation here.
    Van Fan rallycar_jepsen's Avatar
    1991 Previa LE RWD & 1991 Previa LE RWD
    Jul 2020
    Ohio, USA
    Re: unhappy day
    Oh no! Glad you're OK, first of all, assuming this happened with you inside.
    Any indication that the frame has suffered at all or does it just look like front clip and accessory bay stuff?
    Best of luck in this process. Never something you want to be dealing with.
    97 Previa DX AWD
    Re: unhappy day
    Not sure I'm qualified to evaluate frame damage, I may have to have someone come look at it. To me it looks like the right side frame extension (to which the steel bumper bolts) is a bit wonky, but that's not where the impact was. A previous owner did have an accident on the right front side many years ago so it's possible it was bent then. I have always suspected lingering damage because the right wheel rubs on hard turns. I'm not sure how important that part of the frame is, certainly the main frame could not have been damaged by this.
    I cut some holes in the bumper and took the bumper off, and the ac core is certainly badly mangled. I've never messed with the high pressure side of ac before but the low pressure side is reading 0 if my gauge is working. I'd have to get that ac off before I can really assess the radiator but I can see it impacted the fan. I won't do remove the ac core unless I'm sure it deflated. Would sure be nice if I can this driveable for local use because it will be 3 weeks before I can get my 4runner in proper running order. But that seems unlikely to happen fast enough.
    Thankfully I have my 93 parts van and a lot of the front parts are interchangeable, and some of them aren't even rusted. I may have a pretty hip looking tutti-frutti Previa if I can get it going again.
    97 Previa DX AWD
    Re: unhappy day
    I think I have taken it as far as I can without any knowledge of what I'm doing lol. I need an exploded view of the whole front end, not individual components. Ive got the bumpers and grill off, discovering in the process that my left headlight assembly is shattered on the back end. But now I'm faced with a bunch of molded sheet metal, like where the headlights are recessed, that all seem to be (spot welded?) together AND possibly to the forward frame extensions with no visible way of removal. And all that stuff is bent and has to go. I still can't see any way of pulling the front out far enough so that I can at least see in there. I could wrap a strap around everything in front of the fan and tie that to a tree I guess, but I'd want to try and protect the radiator from further damage so I can still run it. I know it will need to be replaced before it can hit the road again...if it can hit the road again
    I presume not too many Previa owners have been in this boat, maybe I should find a collision repair group
    97 Previa DX AWD
    Re: unhappy day
    I managed to get the blower and housing out, being slightly but reparably broken helped. Then I got the partial upper shround thingie out and I can now see the back of the radiator from above. One of the fan blades broke off. When I squeezed the lower hose trying to get the main shroud off, I heard the telltale spitting of a hole near the top of the radiator. I think I have to remove one or both hoses to get the shroud off, it doesnt look broken so I don't want to break it. The blower housing had been pushed up against the wiper linkage, disconnecting the link, which I think that is an easy fix but didn't pay much attention. (Edit: it popped right back on.) Not knowing how much coolant is in there has me nervous about running it to try and pull it out, once I even get to that point. I think maybe taking the radiator out completely so I can assess the situation better, then using my other vehicle for "dent pulling" might be the way forward. I called the only body shop within 30 miles for an opinion on the frame, they said they'd come out today but I suspected they wouldn't come. And I was right.
    Everything behind the fan looks OK. I don't think the frame cross member is damaged at all, and that's all that matters.
    Needs new headlight
    new fan
    new steel bumper (I may have one)
    new rubber bumper (I have one)
    new PS reservoir
    new ac condensor (these are apparently different then my 93's)
    new radiator (" " " ")
    new grill (I have one)
    new hood (I have one)
    repair or replace blower housing (I have one).
    repair/replace intake "scoop"
    I can do all of that, so all I really need is
    1) someone who knows wtf they're doing to straighten things so I have an aligned surface to work with
    2) front fenders may need straightening/alignment/adjustment. One is pinching the driver's door and the other separated an inch or so from the windshield area. Mostly cosmetic so not critical
    97 Previa DX AWD
    Re: unhappy day
    FSM:
    1) Remove the receiver
    2) remove the bolts holding the condensor
    ME: So where TF are the F$#@ bolts holding the condensor? I've spent forever trying to find them!
    Just venting.
    97 Previa DX AWD
    Re: unhappy day
    OK, I figured out how to get the condensor out. Going against Man_btc's signature advice ""If you find yourself holding a sledgehammer or a crowbar, it's time for a break." i reached for the crowbar and pried that sun of a bee out. The bolts I had already removed, and just didn't know it by the way that sucker was wedged in there.
    Now we are getting somewhere!!!! Now the secrets of what holds the Previa front end together are finally exposed, and there really isn't anything holding it together. It appears that nothing but sheet metal holds everything in place. I expected something more substantial but haven't found it yet. The radiator is almost unscathed on the front side. It appears that nothing holds it and the condensor and the grill in place but sheet metal, mostly the cross member where the hood latch is and a couple wings of metal coming from the sides. That cross member is probably unsalvageable if I want a hood that closes but a new one could be welded in easily, though not by me. It might even be bolted in, I haven't investigated it much yet
    This might not be as impossible as I originally thought. I doubt the front will ever be pretty again but I might just go for the demolition derby look. But I don't want to get too far ahead. I still need to get the fan out of the radiator shroud, fill it with coolant, and see if it can run and drive to evaluate it for more serious problems that I don't think it will have. I think I can use this radiator for the testing-the upper radiator hose is still completely full so I don't think I've lost much coolant at all.
    97 Previa DX AWD
    Re: unhappy day
    It looks like the 3 main body parts I need to replace are known as the radiator support sub assembly, and includes the parts behind the headlights.
    https://www.megazip.net/zapchasti-dl...497139-449713933cb8aa2835b061c3a0e371744a443d3.jpg
    They appear to be all welded together since no bolts or screws are shown, am I wrong in my interpretation? But are they also welded to the fender aprons? Guess I'll find out. Still, shouldn't be a big deal if I can source clean ones and find a welder. I'll have to check if my 93 parts van falls within the date range for that assembly...it may not.
    97 Previa DX AWD
    Re: unhappy day
    Rats. Those parts are not the same on my 93, although I wonder how different they could be. They use the same diagram. i could pull a headlight on the 93 and see what's different, but maybe I shouldn't bother. There could be subtle differences that affect which radiator and condensor I can use (I know those are different) so i should probably source the correct parts to save myself future headaches.
    There are 3 apparently good front ends listed in my state online, including one less than 30 miles away. I suspect they are long gone but will find out Monday
    97 Previa DX AWD
    Re: unhappy day
    Good news and bad news. The bad news is I pulled the bumper cover off the 93, only to find the bumper behind it (they call it a "reinforcement") uselessly rusted. The other bad news is by measuring the reinforcement bolt spacing on the 93 I determined that the front passenger side frame extension (for lack of a better term) is bent 3" toward center, as I suspected. There was no impact there either-this bend came entirely from the giant V I put in the reinforcement, which apparently pulled that frame member toward center.
    The good news is there is a perfect front end in a salvage yard not 30 miles from here, so if that bumper isn't rusted I shouldn't be wanting for parts. I talked to the local collision repair and the frame can probably be repaired for 300-500. So assuming no other surprises once it's on the lift I should be able to get it back on the road, albeit differently colored, for about a grand, doing all of the other work myself.
    Edit: I just learned Previas don't actually have a frame, its a unibody. Never knew dat.
    Re: unhappy day
    Sorry to hear about that. I got one with front end damage years ago (although not quite as bad). I fixed it in this thread: https://www.toyotavantech.com/forum/...ont-end-Damage
    97 Previa DX AWD
    Re: unhappy day
    Oh, oh oh awesome!!!! Thank you for that link!! Its good to know I am not the first going into what is totally uncharted waters for me. I guess your "core support" is my "radiator support assembly", and you even figured how I can get the new used one attached for me! (I certainly don't weld). I hope you will check in more as I will surely run into questions and problems.
    Today I hooked up some straps and pulled the tie bar out a bit (what I was calling the cross-member before) and drained the radiator so I can remove it and reinstall it for test runs. Pulling the tie bar dismounted it, but that was a good thing because until it dismounted I wasn't even sure how it mounted. I think once I get the shroud out of the way I can remount rad and test drive. Replacing the fan with one broken blade is probably optional for now.
    I even started to wonder if I can straighten that bent "frame extension" myself. I'm not sure of the wisdom of pulling on it sideways using redneck methods though, would I possibly damage wheel bearings or steering? I was thinking to insert a heavy steel pipe as a lever, I wouldn't attempt to pull directly on the "frame" which would be pointless
    Re: unhappy day
    Probably not a good idea to run it with the broken fan. It will very likely be quite unbalanced and may have other cracks that could cause it to grenade when it starts spinning at speed. Your progress is looking great by the way! I've done some jobs like that. It always seems intimidating until you get started and then, aside from the damage you couldn't see, the actual repairs are easier than you thought they'd be. Plus you always learn something along the way that makes the job easier the next time you have to do it.
    97 Previa DX AWD
    Re: unhappy day
    Good point, I didn't think about that. I finally got the radiator out so getting the fan out should be a cinch. I may have it ready to test drive this weekend
    97 Previa DX AWD
    Re: unhappy day
    Couple questions came up once I got the radiator off and could see a bit better. It looks like something may have become dislodged from the side of the throttle body.
    There's 2 screws there that look like they should be holding something.
    I found a picture on another thread here that appears to show a black cover of something that is attached by those screws, but I'm not sure what it is or how it may affect running. Is that the throttle position sensor? I know it starts and runs but I haven't run it more than 30 seconds
    Re: unhappy day
    I can't really tell from that picture, but if it is the TPS, the rest of it should be hanging from the wires near that location. The TPS is a bit more important on the automatic transmission Previas as it also influences the transmission shift points.
    If the Frame extensions are bent very bad, after it's apart I'd probably trailer it to a frame shop for straightening. There may be other redneck things you could do, but most frame shop guys know their craft and they should be able to make short work of it. What money it costs will be well worth it. It's always best to "build back" on a straight foundation. Tim
    97 Previa DX AWD
    Re: unhappy day
    I think the TPS is on the other side of the throttle body. It appears intact.
    There is something dangling nearby, but that was going to be a separate question. Whatever it is has a bracket where 2 screws or bolts should attach it to something, but it wouldn't fit on those throttle body screws. They are too closely spaced and the hoses don't reach that far. It has a bunch of hoses and an electrical component, whatever it is. I'm going blind trying to decipher parts diagrams
    It may have been dangling all along, I dunno, it doesn't get in the way of anything but the mounting bracket is presumably there for a reason.
    97 Previa DX AWD
    Re: unhappy day
    Here's a better view of that thing. Hoses connect it to the supercharger and throttle apparatus so i presume its some sort of sensor or tells the SC when to do or not do it's thing. I can tell it was mounted by at least one bolt at one time, but it doesn't look real fresh, the other bolt hole is unmarked so it may have dangled free for a long time.
    And oh look! The best view you'll ever get of an all-wheel drive's SC dipstick! Guess Ill check it while the checking is easy. Ahh no, thats not it. Sure looked like it from the picture though. Its just as hard to see and reach as ever.
    Am I correct that a power steering reservoir is a power steering reservoir is a power steering reservoir? Mine is broken, but I have the 93 reservoir. They arent interchangeable part #s but only visible difference is how it mounts and where the hose exits and goes to the pump, so I presume it will be fine to wire it up for test driving purposes. I need something to keep fluid from pumping out all over, and power steering will be a big help for diagnosing any steering issues.
    97 Previa DX AWD
    Re: unhappy day
    Well I started it but the idle is high and the radiator sprays a fine spray of coolant all over the underhood area. I took it out to the corner 50 feet from my driveway and did a couple circles each direction. It felt fine, the steering was fine, although I didn't test it for pulling on straightaways it responds perfectly in turns. It started screaming though, so I came right back. Sounds like something from the belt driven components, but that remains to be seen. Sure hope it's not SADS related, might just be because belts were wet. I will have to buy a radiator for any more lengthy testing, still some troubles ahead but it's progress! (I think)
