I purchased a 1994 Previa S/C AllTrac LE this week, and carefully checked engine oil and coolant levels before driving home (50 miles), but I foolishly relied on the fact that the seller showed me a receipt indicating that the vehicle had just had the transmission checked and fluid changed by her regular shop (NOT a Toyota dealer). By the time I got home I noticed that there seemed to be a slight growling sound in the transmission at low speeds (10 to 25 mph), so I checked the transmission fluid level immediately upon arrival, when it was hot. To my astonishment, the fluid on the dip stick was about 4 inches above "hot full"!! The next morning I drained the excess fluid -- exactly two liters! The fluid is very dark red in color, but does not seem to smell burnt. In a two-liter clear soda bottle I cannot begin to see through the fluid. Considering the extent to which I and other prospective purchasers drove it before I checked the fluid level, I estimate that the vehicle must have been driven with transmission sump so seriously over-filled for 4 hours minimum. What are the most likely indications of possible damage for which I should be especially vigilant? Of course, I will want to change transmission fluid very soon (I plan to use AMSOIL Multi-Vehicle ATF), but my understanding is that, short of removing the transmission, the only way to see that MOST of the fluid is new is to flush the transmission with the new fluid so that the old fluid in the torque converter is flushed, but the high price for doing that would be almost prohibitive for me. Is there any less expensive way to change more than about half of the ATF other than either to flush with new, expensive ATF, or to change fluids two or three times over the next year? Any advice for this first-time Previa owner (who is mechanically adept, but is NOT a professional mechanic) will be most sincerely appreciated.
